Idea #2 a AWD build.
Building a Middy? This forum is for discussion of builds that don't follow the traditional Locost design.
Moderators: dhempy, horizenjob, mr.peabody.d
B85
Re: Idea #2 a AWD build.
Post by B85 »
Shoulder is feeling better. This is taking to long !!
Oh. and the AWD Forester with my old Sti. stuff "works" . :shock:
https://www.youtube.com/watch?v=QUnlEMo ... e=youtu.be
American 7 5.0 T5
Lotus 15 ish?
914/H6
B85
Post by B85 »
Good day !
Springs are here and in ! Think this will work.
Cut the spring ring off. Just to close.
It sits just about the way I think it should ?
Also the LSD works just fine! Open diff up front.
So a good day. Will reinstall front brakes Thus. Almost a driver? And looks to have good POWER!
Randy
Also got the co-drivers seat in.
Its is not where I started with the idea but think its going to be fun!
American 7 5.0 T5
Lotus 15 ish?
914/H6
B85
Post by B85 »
More work on the rear pipe and muffler. Have been thinking about comeing off a jump and felt the flowmaster is heavy and would need a better hanger. Came up with this. What do you think ? Still need a V band clamp to finish.
And some hangers.
And a end shot. Think it will work with the tube bumper ?
Randy
American 7 5.0 T5
Lotus 15 ish?
914/H6
B85
Post by B85 »
Test drive. Just for fun!
https://www.youtube.com/watch?v=BknUGJ2 ... e=youtu.be
And with white doors.
Randy
I know,its not a 7 ! :oops:
American 7 5.0 T5
Lotus 15 ish?
914/H6
B85
Post by B85 »
Do not ask ,it just looked like the next thing to do ?
Well, today started the first part of this build that is for "RALLY" ! Worked on the front coilover tower reinforcement . This will have a tower brace also !
First you clean off the paint and body filler. Also good time to do some seam welding .
Then get some paper and cut out the form you need.
Then cut the plate.
Then fit.
Then weld. Will post that Friday.
Randy
P.S. Think I will be adding struts to the Lotus15 rear end. Working it out now. Think I can make it work now that I have been playing with the Forester coilover thing.
American 7 5.0 T5
Lotus 15 ish?
914/H6
B85
Post by B85 »
:oops: .I started the main cage bar. First some bending from the plan.
Then a test fit.
Then some triming and more triming. Then some tube knoching.
And some welding.
And poof a main bar !
Some more fitting , got it about 1/16" off the main roof side frames. Kool !
And a side shot. Cleared all the door handles .
For now I will just tack the main.Will start on the overhead door bars in the AM.
Randy
American 7 5.0 T5
Lotus 15 ish?
914/H6
B85
Post by B85 »
Cage is just about done ! I know I am ! :ack:
American 7 5.0 T5
Lotus 15 ish?
914/H6
B85
Post by B85 »
Look what I got ! Kool !! :mrgreen:
American 7 5.0 T5
Lotus 15 ish?
914/H6
