It is currently July 24, 2021, 11:18 pm
Post new topic Reply to topic  [ 304 posts ]  Go to page 1, 2, 3, 4, 5 ... 21  Next
 Post subject: Too Busy's Mk I Mini
PostPosted: August 31, 2014, 8:04 pm
I hope you guys don't mind, but I'd like to do a build log here for my Mini resto-mod project.
Here she is as I picked her up. A pretty basic 1964 Mini from New Zealand. Looks like the original color was red and she's had at least one repaint. Current color is orange. I'm thinking that this could / should be my Clemson car.
Doors are nice and solid on both sides
A pillars look good
B pillars look good
C pillars even look good
There is some rust at the body seam of the C pillar on the right side. Pretty sure I'll find some rust in there
There is a small hole in the passenger floor panel. It feels pretty firm. I'll know more later
There is some bubbling at the bottom of the front wing and in the bottom of the outer rocker. Doesn't seem to have filler in it, so that's a plus.
I put it on jack stands today and the bottom looks better than I thought it would. The rear subframe has some dings, but nothing other than surface rust.
The front subframe has been liberally coated with rust preventive motor oil courtesy of the little A series engine.
I think I'll spend some time with her tomorrow and do some light disassembly. Bonnet, doors, boot lid, rear windows, pull the interior...
more to follow
 Post subject: Re: Too Busy's Mk I Mini
PostPosted: August 31, 2014, 10:46 pm
Nice one. I'll enjoy following your progress on this project.
Heck no, we* don't mind your build log. But some of us might mind the placement. To quote The Guidelines, "Here is where the build logs go for non-traditional build logs. Mid-engine, three wheelers, you name it. If it's not your typical Locost it goes here." So by the power vested in me as a mod, I've moved this topic into the non-trad forum.
*I'm not royalty, and I'm not an editor, but I do have fleas and am thus justified in my use of the plural.
PostPosted: September 1, 2014, 6:29 am
Great. Thanks Jack
PostPosted: September 1, 2014, 7:05 am
I find new bubbles to clean out every time I turn around on the spitfire. Kimini doesn't have that problem!
How do the lower inside door glass sliders work? I see a chrome tube with a knob on it as best I can tell from your pics.
PostPosted: September 1, 2014, 7:26 am
The windows ride in felt lined channels. The latches bolt to the window glass and the "latch" is just a pin that goes into the holes on the aluminum trim piece.
Push the button the retract the pin and slide the window.
here's a better pic
Not just no, but HELL NO! Any color but orange... *Note* I might be biased.
PostPosted: September 1, 2014, 7:30 am
I think orange body, white roof, and a BIG AZZ paw print on the roof
PostPosted: September 1, 2014, 7:35 am
Thanks for the clarification. I was looking at ways to improve the sliding windows on the trike.
PostPosted: September 1, 2014, 10:27 am
Tom pretty kewl!
PostPosted: September 1, 2014, 3:43 pm
Locostering Legend
Saw this window sticker last week:
PostPosted: September 1, 2014, 3:55 pm
Very cool project. Glad to see you finally found one.
PostPosted: September 1, 2014, 7:30 pm
Decided to start blowing apart the Mini today. I wish I could say it was easy, but she fought me every step of the way.
First, pull the grill, no problem.
Then front bumper. One side easy, other side the stud on the bumper spins in the hole... no way to get a wrench in there. Come back to that later.
Back bumper, One side stud shears off, other side spins like the one on the front. :BH:
Ooooh Dear previous owner, these wires are too small for a 30 amp circuit.
As far as I can tell, this screw up by the DPO is what took the car off the road. I think he was having a problem either with the switch or the starter solenoid and decided to put a hot wire from the battery main fuse thru the switch, to the starter solenoid, to ground.
I pulled the plugs, squirted a little oil down the bores, and spun the motor by hand. Compression on all 4 cylinders. I haven't calibrated my finger lately, so you'll have to wait before I call it good.
The electrical fire took out a couple of other wires in the bundle that goes to the binnacle. :shock: Good news though. Remove the stooopid and connect the battery. Lights work, signals work, but blink really really slow, heater fan works.
The wire bundle smells like burned plastic, so it's coming out.
I traced back wires, checked against my wiring diagram and put in a temporary wire of my own using 12 gauge, a solenoid and a start button. I just want to fire it up and take a couple of laps around the neighborhood before I blow it apart. Best thing about an old car all I need is power to the starter and coil to make it run.
WOOOOOOOOOOOOO FREAKIN HOOOOOOOOOOOOOOOO!!!!!!!!!!!!!! She runs, doesn't smoke and goes through the gears!
Brakes suck, I'll bet a find leaking slaves when it comes apart.
Let's blow this baby apart and get after it.
I was scared years ago the first time I stripped a harness out of a car. That was FrankenSprite. Now after Tetanus and the R1 project I don't even give it a thought.
Wires coming out.
All that's gotta go
Disconnect the speedo and combo gauge and instant hole in dash. That created some space to remove the heater and the switch panel. While I was in there, might as well pull the steering column.
Time to see what it looks like down low in the rear.
Right side
Left side. Looks like I'll be spending some time cutting and welding back here. Floor pan and a bit in the inner rocker.
Pull the seats, pop the doors off and call it a day.
PostPosted: September 3, 2014, 2:21 pm
Storming here last night so I didn't do anything on the Mini. Hopefully today I'll get a couple of hours in the garage after work and have the engine / trans pulled... we shall see
Once I get the engine out, she'll come off jack stands to drag outside for a SERIOUS pressure washing. All of the fiddly bits will already be off the car, so I plan to hit it with 2000 psi inside and out with some degreaser or TSP in the mix.
I want to get all the dirt, any loose paint, loose rust, grease, and grime off the car before this weekend rolls around. Saturday morning I'm headed to my local metal / scrap yard to pick up a sheet of 16 gauge mild steel.
With the bead roller, good shears, two different metal brakes, and English wheel available I plan to make as many of my own patch panels as possible. There are parts I know are outside my scope and abilities, no so sense spending $50 on a floor pan that I can make in an hour or so.
PostPosted: September 4, 2014, 8:47 am
You're having fun. A thick, brush-on rust dissolver would be nice though. You may want to mix up some waxoil.
I had two rounded off bolts holding my torque converter to the flywheel on the trike that I had to grind off. Also a few blind fasteners that kept spinning. I guess the square hole in the bumper is rounded out, letting the bolt spin?
PostPosted: September 4, 2014, 9:33 am
It might be a good idea to buy some Naval Jelly when I get it all cleaned up. Let the chemicals do the nasty work. I was watching a youtube video last night about dustless paint stripping. Looks like there's a kit to attach a sandblast nozzle to a pressure washer... could make short work of the couple of heavy layers of paint on the body... Of course it could make short work of all the bodywork as well.
Waxoil is definitely in this cars future. So is some weld through primer and POR15 :wink:
I'm not sure if the square hole is round or if the corners of the carriage bolt are gone. Either way it's a great big pain in the arse. I'll bust out the welder and tack the bolt to the bumper this weekend.
Last night I tried to make some headway removing the engine. I kept getting visits from one of the neighborhood kids. Every time he rode by on his bike, he would come in and poke around the garage for a few minutes.
Then a buddy of mine came by to ask a couple of questions about the Volvo he just bought and he hung around chatting for an hour or so.
Finally started wrenching on the car about 7:30. I wanted to get the radiator out. Man o man a lot of work in tight spaces. 8 bolts holding the shroud to the rad, 2 bolts holding the bracket to the thermostat housing, 2 more bolts holding the bottom bracket to the chassis, then pull the hoses and catch the spillage in a bucket.
The radiator shroud has some SHARP edges. It doesn't look too bad today, but I bled like a stuck pig last night.
Pulled the radiator, crawled under to unbolt the exhaust. What moron welds the exhaust full length from header to tip? I'll have to sawzall the pipe to get the header out of the way.
Tonight I'll pull the u bolts from the rubber couplers, remove the shifter, unbolt the motor mounts. She should be ready to lift out.
