It is currently April 17, 2024, 10:42 pm
 Post subject: Briggs' 2002 Subaru WRX
PostPosted: February 1, 2017, 6:51 am
Hello gents! figured I start a little build log for the Subaru.
I drove up to PA in Jan of 2016 with a friend and picked up a mint 2002 WRX wagon with leather interior and 182,xxx miles on it. Drove it 600 miles back down to NC and we had our first snow storm so I drove it around for 3 days while that cleared up and parked it in the garage. I had a Miata at the time and there was no way I was about to drive that on ice/snow.
Once in the garage I pulled everything off to replace the timing belt, water pump, fuel filter, spark plugs, every vacuum hose that I touched. I purchased a new intake boot, and replaced the rear engine (pitch) mount bolt as it was missing.
Following a timing belt replacement video on YouTube and everything went smoothly. She fired right up with no issues, minus the power steering line I forgot to connect back... whoops...
At the beginning of November I picked up a new daily. A 2006 Volvo V70R, pretty much my shop car to help promote the business. I bought this from Matt, a friend of mine who came to me so I could make a custom downpipe for the car as no one sells one for less then $900. More on that later.
In November I placed a decent size order with Amazon, eBay, and some other companies.
List of parts I bought...
700cc injectors. I had to email the company I bought them from as the 2 on the passenger side were pouring fuel all over the exhaust and that's a cause for fire that I rather not have. They emailed me back the next day and sent out a new set of O-rings. I let a friend of mine install them while I was installing the fuel pump. Turns out there was a bunch of dirt in the TGV's (lower intake manifold) and the O-rings wouldn't seal correctly causing the leak.
255LPH fuel pump kit. No issues here, which is what you expect from Walbro.
Top mount intercooler with all new hoses and charge pipes. I decided to stick with the top mount setup as it's good to about 350whp and the charge pipes account for maybe 12" of piping total. Plus, I hate front mounts on these cars. No picture of it, I'll have one soon.
I bought a cheap ($90) downpipe for the car off eBay, because why not? What's the worst that could happen? Figured it was worth a shot and I didn't feel like making the bellmouth section of the pipe near the turbo. Pulled the oem downpipe with its 2 cats off and what do you know, hits everything... Doesn't sit flush on the turbo, hitting the subframe, and is pushing the AC drip hose over, nothing better then a burnt rubber hose and a wet downpipe every time the AC is on.. So I decided to cut it up and use its parts for a proper downpipe, by parts I mean bellmouth section and the flange for the turbo and the 2 bends at the end that they actually got right. The flange on the catback side was also the wrong piece. I'm going with a v-band connection there so no harm no foul also added a flex after the trans mount bracket. I'm in the middle of building the downpipe currently. I'm using pie cuts as this is no easy task and there's not much room down there.
This is all I can use from the downpipe. Rest will be pie cuts and straight sections.
I also ordered a spin-tech 3" in and out muffler. This is a company Ken told me about. He used to have one of these mufflers on a older Jetta. I built his exhaust for his 1998 Volvo v70 and I love the way it sounds.
No resonator on my car. Just the muffler. To limit drone I'm going to be building a antidrone pipe right before the muffler. V8 guys love them and it should cut down on highway noise, especially this being a wagon. I ordered 2 tips, 1 dual and 1 a very large oval. Going to decide on which one I like better.
Muffler and tips are on the way.
Ordered 2 catch cans so I can run a dual setup. They came with a crappy mounting system and I wanted them to sit next to each other in the engine bay. So l made JD favorite things in the world... br&ckets!! Ended up making 1 in 16 gauge and it was too thin. Stepped up to 1/8", much better.
Yet another headache and custom piece I had to build was the intake. I ordered one off of eBay as it was $42 shipped and came with everything... so I thought. Go to install it and nothing lines up. The pipe in the fender is 3" and then it reduces to 2-3/4". My turbo intake boot is 3" and I rather not have a bottle neck in my intake. Emailed the guy he says that the stock MAF is 2-3/4" and going larger in side can mess up the readings of the MAF. I agree but .20" isn't going to make a huge difference. So I placed yet another order with my supplier and got to welding, this time on aluminum. Learning a lot with this trash. I had to cut out the MAF adapter and weld it to the 3" elbow that I ordered. The MAF adapter was so dirty, just crappy aluminum. It was quite the challenge to weld. I also extended the pipe in the fender as it didn't stick out far enough to clamp the boot on. I decided to use a 45* silicone elbow to help make things easier for me. I watched idk how many videos on YouTube and asked a bunch of questions on my Instagram. I'm getting there. Still lots to improve. Aluminum is a different beast. You think it's clean, clean some more, tack and clean again before final welding.
Before
After
I couldn't find a gauge pod that I liked. Well more so one that wasn't $$$. I ordered 2 dual pillar setups, a LHD one and a RHD one, and cut them both down. It isn't perfect but once it's in the car it's hard to tell. Working with ABS plastic is always fun but it sure does make a big mess. Almost like fiberglass minus the itch. I used a scotch bright pad on my air grinder to get the big portions. It's still a work in progress. Hopefully it will look good once it's painted. I need to find a paint that will match my interior, or come close.
On the right is the wideband, on the left is the boost. Works out perfect and doesn't block any of the gauge cluster.
I need to send back the wideband as it isn't compatible with my engine management solftwate.
For engine management I went with open source (standalone). A company called Tactrix builds the OBD port, they also send a cable a that plugs into the OBD port. I then can change everything with a software called Rom-Raider and upload the changes with a software called EcuFlash. Also ordered a boost controller solenoid. The software is free and I know a great tuner.
PostPosted: February 1, 2017, 7:13 am
Pic from this years snow storm. I can't wait till next year. That's the only time I can do donuts in the car. It's such a blast to drive in the snow.
PostPosted: February 1, 2017, 3:41 pm
DUH, what's an anti-drone pipe?
PostPosted: February 1, 2017, 3:56 pm
It's a smaller pipe 1.5-2" in diameter roughly 20-30" long. You T it off the exhaust pipe before the muffler and you cap the other end. At WOT the exhaust gases pass by the small opening. At partial throttle they enter the pipe and bounce back and cancel each other out causing the exhaust note to be much quieter. I'm curious to test them. I have a app that measures noise levels.
PostPosted: February 1, 2017, 5:54 pm
Helmholtz resonator then. That has to be tuned to the proper diameter and length to work. It's not as simple as just sticking any old size pipe on there. It comes stock on all S2000s.
I was hoping you had something that didn't require the tuning. One size fits all kind of thing.
PostPosted: February 2, 2017, 1:46 am
Sort of. The helmholtz resonator is the same idea just fab'd differently. Yes, you are correct. I'll have to do some readings before I make it to figure out what size piping and what length to go with, once I figure out how quiet I want it to be. It's not that difficult, there's a formula for it.
That's also why I said 1.5-2" pipe with "roughly" (key word there) 20-30 inches long. The one on the S2000's is tiny, it's only 3-6" long and honestly isn't needed given how large both the stock mufflers are as well as the way they are designed being dual chambers.
Honestly, 1.5" pipe at 10-20" long is going to be plenty. Anything is better then nothing. Tho it may not be tuned for your application it's still going to do its job in cancelling out the exhaust waves.
PostPosted: February 2, 2017, 2:57 pm
I'm glad you guys brought up this anti-drone topic 8)
I've seen these pipes, but never knew their function.. now it's likely something I'll incorporate into my build, as I'm worried about the funky sounds (drone) my little 4-banger will likely make.. I'm getting old, and tend to like my 'everyday' exhaust to be quiet (when it's time to get loud is what a cutout switch is for :twisted: )
--ccrunner
Dean
1963 Volvo P1800 Restomod
viewtopic.php?f=36&t=19397
PostPosted: February 2, 2017, 7:31 pm
The one on the S most definitely is needed. They drone like a son of a gun without it.
I'd be interested in seeing that formula you spoke of.
And everyone knows size doesn't matter.
PostPosted: February 3, 2017, 1:39 am
Found it.
http://www.performancetrucks.net/forums ... ne-489463/
PostPosted: February 3, 2017, 1:41 am
--ccrunner
That would be hard to do with these cars unless you could find a way to shoot the pipe back into the chassis. Too many bends in the pipe and the exhaust gases will bounce off the bends and not the cap on the end.
PostPosted: February 21, 2017, 7:03 am
Catch cans and turbo coolant tank installed. This took a lot longer then it should have. Most of it was the injectors. They are a little loose and I really hope they don't leak again.
Next is the exhaust. Really need to get that knocked out. In order for me to get the tips where I want them I'm going to have to cut up the tow hitch and move it up some.
