It is currently March 24, 2019, 8:49 am
Post new topic Reply to topic  [ 1 post ]
PostPosted: September 1, 2017, 3:47 pm
So I am in the process of ordering new custom adjustable bilsteins (my car seems to be too light in the front to buy anything off the shelf). What i am having issue with is making a graph of what I want Bilstein to make.
Using this cacualtor
http://farnorthracing.com/autocross_secrets16.html
This is what I have but what values do you guys think would be fitting for Tire spring (its hard to measure), design Dampening ratio and digressive knee?
My front spring rate is off since my front shocks are really over damped and I would think it should be closer to 125lbs. The rears are not too bad.
* Most spring calculators assume you don't have push rod supension.
http://www.ridetech.com/info/wp-content ... ulator.xls
I actually did this for the other car I was working and the driver ended up using a very slow rebound (2 click out of 10) because he thought it was too harsh. I think it is great.
Here is what i get if I use the built in Tire spring rate, design Dampening ratio and digressive knee
