It is currently February 22, 2019, 3:03 am
PostPosted: June 20, 2017, 11:14 am
I have been a bit lazy in my reporting. However my build (1965 Corvair powered rear engine locost) is still on track. I will try to file some pics to prove it. If I can manage it this time.
OK, it looks that I have the pictures in. What you can see here is the not complete chassis of a locost that will have a roof (coupé), the engine behind the seats, the spare wheel, and removable doors are in the front under the hood , as well as the fuel tank and the water tank (not there yet). Although the chassis is a space frame inspired by Champion's Book drawings, I have made many changes. I have used more G16 1 1/4" tubes and my entire suspension and steering are different. I.e I am using semi elliptical leaf springs everywhere and my steering calls for a Pittman arm gear . I will detail all this later. My suspension too is my own design. Not necessarily better but stronger, I think.
PostPosted: October 10, 2017, 4:52 pm
Any progress in the last few months?
PostPosted: October 16, 2017, 6:38 am
File comment: Shaping the roof with balsa core.
Thanks for your interest.
Yes , I have worked on the roof.
Of interest to some, perhaps. Here is what I have been doing.
The tube frame was tack welded entirely minus the engine brackets and rear suspension attachment. The roof was lined roughly with thin wooden planks (1/4 x 3). And 1/2" balsa core was stapled on the wooden plug (male mold). Now (not seen on this picture) I have spread West two part resin with slow hardener. Sanded extensively.
Coming up: glass fiber layering, more resin, more fairing, etc until the shell looks OK. I will then brace the roof with a sort of metal cradle, remove it from the chassis, turn it over and glass the inside (which is less demanding). The shell will then be parked somewhere until the Spring and then finished. This Winter (Canada) I will complete the welding and finishing of the chassis. I will try to post more pictures as I go.
File comment: Building a glass roof
PostPosted: October 17, 2017, 3:24 pm
That's a cool idea for building a hard top, it should be plenty stiff and light. Are you going to remove the 1/4" x 3" planks before glassing the inside, or are they staying with the balsa?
Kristian
viewtopic.php?f=35&t=7587
viewtopic.php?f=33&t=18172
PostPosted: October 17, 2017, 3:31 pm
Apparently balsa makes a good stiffener and sound deadener. Chevy used it in the floors of the C-5 Vettes, and presumably in the 6s and 7s!
PostPosted: October 18, 2017, 7:15 am
Kristian
Thanks,
I thought of leaving the pine plank plug in place and decided not to. For 2 reasons:
Weight
And mostly because the resulting GF lamination would be weak. Indeed core fiber glass laminations rely on a direct resin bond between the core surface (in this case balsa wood) and GF. The pine planks in my system are only there to provide a plug or male mold. Balsa is only stapled to them. I will therefore have to peel off all these boards, breaking them in the process prior to fiber glassing the inside. :cheers:
