It is currently February 22, 2019, 3:00 am
Post new topic Reply to topic  [ 83 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6
PostPosted: October 15, 2017, 4:05 pm
Good to hear from you again! Keep us posted. :D
PostPosted: March 8, 2018, 11:35 pm
locofinn wrote:
Fired it up for the first time last night. Everything looks good so far. Hope to be on the track yet this fall to start the sort process.
Hi, Mark! Thanks for the great info about this tranny/engine. I have Isuzu T5 in my garage and I'm on the market for GM 1.4. Do you actually get your wiring from http://www.enginewiring.com? I gave them a call yesterday and they can't help with this engine. How you manage to fired it up? Any tricks and tips? Thanks. Victor.
Have Fun!
My build log: http://locostusa.com/forums/viewtopic.php?f=35&t=19323
My Instagram: https://www.instagram.com/Shortcut_us/
PostPosted: March 18, 2018, 8:15 pm
Enginewiring.com did mine but it took them a long time to get it done. Not sure it is a high production project for them as they seem more interested in LS engines, etc. Stripping down the harness is not impossible to do, it just takes patience. If I had it to do all over again I would have just done it my self and save a few hundred bucks. The trick is to get the Factory Service Manuals for this motor/Cruze 1.4 for the year motor you have. I'm not big on electronics at all but I ended up revising the wiring a bit by adding a VSS to the harness/PCM. The trick is getting the right tools and the right connectors. YouTube is a wonderful source on how to modify a harnesses for Chevy engine swaps. It can seem overwhelming but once you figure out how the read the factory manuals it makes sense. Everything you learn along the way will be helpful when you have to troubleshoot if something goes wrong.
As I said before, one thing I did leave to a pro was the programming. Overriding the factory programming codes and get the motor to run takes a lot of experience. Without programming knowledge the motor is a large paperweight. Jerry Kinney at Bad News Racing is THE Guru. He has done several using the HP Tuners system. Not cheap but worth it for a custom stand alone engine tune. He had mine running within minutes over the internet on my computer. He was in Florida and I was in my garage in Indiana. Technology can be amazing.
Link to my build log:
PostPosted: March 28, 2018, 5:50 am
I just wanted to say thank you!
I'm in the process of getting and starting an LTG ecotec repower and some of your links are really helpful! Some of the mods and tuning are a black art which is very frustrating..unless you want to spend $2200 on the gm ecu :/.
PostPosted: May 29, 2018, 8:08 pm
So I run mustang T5's in one of my road race cars and have a few parts in inventory. I bought the unicorn Isuzu trans and bellhousing (2 actually, one locked up and one in awesome shape).
Unfortunately there are a few differences on the input side. I have not checked the output side other than shifter location.
Shifter placement: Fox is 19.75 and Isuzu is 18 (from front of trans)
Pilot Bearing Diameter: Fox is 0.677 and Isuzu is 0.599
Bellhousing Register: Fox is 4.914 and Isuzu is 4.685
Input shaft length: Both are very close to 7.125 (using tape measure, no calipers or depth gauge big enough)
Spline count is obviously different also
The front bearing retainers are the main differences. While it is possible to machine the Isuzu bellhousing to fit the fox bearing retainer I do not have the release bearing components to check and see if they work.
The cases do have the same bolt pattern so that is a plus.
I am hoping that I will be able to just put the Isuzu bearing retainer on the ford trans but it probably wont fit. I will keep you guys updated when I have time and space to tear these apart and check everything out.
File comment: Fox T5 on left, Isuzu on right
File comment: Fox T5 on bottom, Isuzu on top
Parts gatherer
PostPosted: September 24, 2018, 9:13 am
Finally, got the tuning working. Big tip: Make sure you are using the operating system in your factory ECU from a manual transmission car so it can read the VSS signal. We had a tough time figuring this out as my ECU came from an auto transmission car and would not read the VSS. Without the proper (or any) speed signal, the ECU limited the redline to 4,000 RPM as a safety default to prevent overrevving in neutral. It took us 2 months to figure that one out! GM engineers really don't want the motor to tune at the higher level it is capable of. Kudo's to Jerry Kinney with Bad News Racing for helping me through this "Stand Alone" engine tune. The car's first outing went well. Our first autocross was 12 runs with my co-driver, William Loring, drove to a 2nd FTD out of 48 drivers just behind a shifter Kart on a very technical sub-40-second course at the Tire Rack test track in South Bend, IN. All objectives were met, additional data logging was accomplished and the car performed very well for a test outing. Very happy with the 1.4T motor. It is pretty civilized until you get on it then it really pulls hard for a basically stock motor. More than enough power even in stock form. Great little motor for a Seven. Looking forward to next year.
http://live.axti.me/live/56e5dc6b10142e ... cc0f354681
PostPosted: September 24, 2018, 4:01 pm
Im glad you got that figured out those kind of problems can be very frustrating. Does the original car have a separate transmission computer? It is odd but not surprising to me that GM would go away from their standard which was that manual transmission computers limit to 4000 rpm without a speed signal input and that automatic cars the computer is looking for a switched signal that the car is out of park or neutral to remove the 4000 RPM limit. Usually all you need to do is jump the correct pins in the computer to remove the limiter. Downside is that on some automatic computers there is no rev limiter at all after that as the transmission will just shift gears to drop RPM.
PostPosted: September 24, 2018, 10:27 pm
Interesting. It is issues like this that make me consider just running an aftermarket ECU like megasquirt. It too has its own set of problems though, like using an oscilloscope on a car to figure out the vvt values.
Parts gatherer
