It is currently April 28, 2024, 4:16 am
Post new topic Reply to topic  [ 2 posts ]
PostPosted: June 12, 2018, 2:17 pm
This may be of interest for the Locost group, I'll be losing my garage space shortly (storage garage), so I have a bunch of items that will need to find a new home. I have the following plus other odds and ends:
Spitfire windscreen (late) - glass only, in decent shape
MG Midget rear axle - missing drums but has new wheel cylinders and shoes, 4.55 (I think) diff
MG Midget half shafts - there's at least two spare but maybe more
Spitfire front uprights - 2 pairs, one set modified for spherical bearings top and bottom, one set drilled out to suit a 5/8" bolt instead of upper ball joint (to use a 5/8" rod end)
Healey Sprite/Midget smooth case gearbox - casing had been crudely modified to fit a Coventry Climax, other than that, condition unknown
(3) Spitfire steel wheels - off a Mk 3 with 4 tires
(1) Seat for maybe a TVR (I've seen a set in a 2500M but cant confirm) - complete with a spare seat frame, would most likely need re-upholstering
Morris Minor axle casing - empty and has a small hole that could be repaired, has brackets to fit a Lotus 7 Series 1
And possibly some other items that I can't remember at the moment.
Also, depending on whether or not I can find storage space, I might have to find a new home for a Lotus Europa S2 chassis that is rusty and has a bent front crossmember.
All items (other than Lotus chassis) $400 obo
PostPosted: August 15, 2018, 2:12 am
Rod
Is the Morris Minor axle casing with brackets for a Lotus Seven Series 1 still for sale please?
If so, how much for it including packing and shipping to the UK please?
Thanks
Mike
