It is currently February 22, 2020, 2:23 am
Post new topic Reply to topic  [ 556 posts ]  Go to page Previous  1 ... 27, 28, 29, 30, 31, 32, 33 ... 38  Next
PostPosted: May 8, 2019, 8:15 pm
I have gotten a bit of work done over the last few weeks. The dash is now steel although not final painted, I wanted it black to get an idea of what it will look like when done. Ultimately, I plan to paint it in a heavy wrinkle finish.
I created the tank straps which use U-bolts for tension.
And I created the curved frame pieces that follow the curve of the rear fender. I am surprised how much these limit the seat sliding backwards. Luckily, I have 2 more clicks backward from where I need to be to reach the pedals (I am 6' 3").
Gavin
PostPosted: May 9, 2019, 10:59 am
It's all looking very nice. I especially like the dash - very clean.
PostPosted: May 9, 2019, 8:33 pm
Thanks Lonnie! All of the gauges are easily visible (although I might rearrange the order) and all switches are easily actuated with gloves on.
Gavin
PostPosted: May 15, 2019, 8:03 am
This week I have been working on the front fender mounts (aka: wing stays). I really don't have to many options as to how to mount the stay to the hub so I used Caterham's idea to use the upper ball joint stud. I have a vertical leg in the front going to the steering arm where the adjustable steering stop would mount. The main piece is 1.5"x 0.125" and the rest is 1.0"x0.125". I plan to use rubber isolator washers to allow the fiberglass fender to move slightly. I also plan to add a gusset at the 45* bend on the vertical leg. Please feel free to make suggestions as this has been an item I was not looking forward to and I am unsure if it will be strong enough.
Gavin
PostPosted: May 15, 2019, 10:50 am
What are the dimensions on those front fenders. I'm having a hack of a time sourcing anything at a reasonable price and will probably end up making my own as well. Looks great.
PostPosted: May 15, 2019, 7:13 pm
They are 37" long when measuring around the arc and 9.5" wide. They were made for a 205/50r15 tire. racepedals made the mold using a steel fender and then added a strip of metal in the middle to create the mold for them.
Gavin
PostPosted: May 25, 2019, 4:03 pm
I got my serial number from the state today (aka: VIN)!! Now I just have to complete the car and take it to the DMV for inspection and it will be a street legal vehicle :)
Gavin
PostPosted: May 25, 2019, 5:00 pm
Looks good. I'm jealous--- I have not been able to touch mine in a long time.
PostPosted: May 27, 2019, 4:33 am
Those fenders do look great. :cheers:
If you are still looking for fender mount input, here are a few mods to what you have that will make it more rigid so it does not flex, work harden, then crack. When/if they do, might want to make them the legs easily removable on the side of the road. Just cut off the legs 3 inches above the ubj, flange both sides of the 3 inches down to the ubj plate, drill two 3/8 bolt holes to hang the legs on, then make new legs that overlap the three inches. Don't worry about unsprung weight when it comes to fender mounts.
PostPosted: May 27, 2019, 3:12 pm
Congratulations to you, of course. Getting a VIN is huge.
On the other hand, I'm even more jealous than Racepedals. :crying:
PostPosted: May 28, 2019, 10:20 pm
The compliments on the fenders go to Racepedals as they are from his mold.
But I agree, I really like the look of them and there is enough "meat" to rotate them toward the rear to guard against kick up from the tires.
Gavin
PostPosted: July 5, 2019, 4:51 pm
MV8: I had similar thoughts but there is very limited room. I might leave it as is to do an auto-x or 2 then beef them up before final install.
Gavin
I am working on the interior panels as I am preparing for my first auto-x in Concord, NC on July 20th. I have created the templates and I am ready to cut the Al but I was wondering if using rivnuts instead of rivets would be okay for the rear bulkhead. I was thinking of using steel M5 rivnuts with button head screws every 8-10 inches or so. I am thinking this for 2 reasons:
1. The chassis isn't complete yet so I will need to remove the bulkhead to finish weld and paint
2. I am sure i have managed to paint myself in a corner somehow that requires access through the bulkhead but i haven't identified it yet :?
Your thoughts?
Gavin
PostPosted: July 16, 2019, 11:08 pm
I have been working frantically to get the car ready for the autocross this weekend. It is an SCCA sanctioned club and I never heard back from them as to whether or not I need a roll bar. So.....
Gavin
PostPosted: July 17, 2019, 7:25 am
I haven't checked the SCCA rules in a while, but Solo (autocross) did not require a roll bar for open cars as of a couple of years ago.
It's not a bad thing to have one though, and if you go much higher in the racing world, you're going to need one any way. Good luck on Sunday!
Users browsing this forum: Majestic-12 [Bot] and 1 guest
