It is currently April 16, 2024, 2:48 pm
 Post subject: Boot Cover Snaps
PostPosted: November 18, 2021, 11:55 am
My boot cover is just about complete and I was planning on just using typical snaps around the perimeter to secure it. The button portion will go on the cloth, which is pretty straightforward, but I've never secured the a snap receptacle to metal before. Can I just rivet them on or do I need a special snap that will work with a rivet? Am I missing something entirely, is there a better way to do this than snaps?
Trochu Motor League
 Post subject: Re: Boot Cover Snaps
PostPosted: November 18, 2021, 12:49 pm
Looking at these 2 links, assuming I'm understanding your desired usage.
Looks like it can be done via rivet or screw. I'd guess the rivets would be better for long term use & less likely to back out
Rivets:
https://www.amazon.com/Stainless-Steel-Snap-Studs-Rivets/dp/B01K3O34SW
Screws:
https://www.amazon.com/Canvas-Diameter-Stainless-Bolt-Dropper/dp/B073K5F61G/ref=pd_bxgy_img_2/140-5528795-4156617?pd_rd_w=Cvq0n&pf_rd_p=c64372fa-c41c-422e-990d-9e034f73989b&pf_rd_r=X99WVD4Z5JNEH6BV3K68&pd_rd_r=604779bd-da29-4c19-bd0a-b158ded92341&pd_rd_wg=GtfYy&pd_rd_i=B073K5F61G&psc=1
1975 MG Midget
13B Powered Rotus Geauxkart
PostPosted: November 18, 2021, 1:39 pm
Rivets work just fine with the normal snaps. You might have to modify the rivet gun tip to get down inside the snap, but that's about the only issue.
PostPosted: November 18, 2021, 2:17 pm
Online
Instead of rivets, machine screws using washers/nuts on the inside could be used if you want removeability. Finding the right sized machine screw head/shank would be necessary. The tops and bottoms of snaps come in standard sizes, just make sure you use matching sets.
Cheers, Tom
PostPosted: November 18, 2021, 4:43 pm
Thanks guys.
I like that idea Tom. Could get a washer back there, spread the load out a bit, and if they ever come lose, could just tighten them up.
Trochu Motor League
PostPosted: November 18, 2021, 8:57 pm
I have always liked the lift-the-dot fasteners for tonneau type covers. Just an option.
https://www.sailrite.com/Lift-The-Dot-M ... wIEALw_wcB
Larry in Seattle
PostPosted: November 19, 2021, 9:39 am
Flat head countersink screws. Is a perfect fit. 8) Just take the button assembly to the hardware store if worried about the fit.
Davew
PostPosted: November 19, 2021, 6:37 pm
You can also buy washers specifically for rivets or drill and cut your own. Use a nylock, lock washers, or jamb nuts on machine screws.
PostPosted: November 21, 2021, 3:52 pm
Those are seriously cool. I’ve seen them before, but wouldn’t have remembered.
PostPosted: November 21, 2021, 11:29 pm
Lift-the-dot fasteners are really old school. They have been around for many years. My 1952 Sunliner had them. However I recall seeing them on much older applications. Look decent and hold quite well. And cheap.
Cheers!
Larry in Seattle
PostPosted: November 24, 2021, 3:11 pm
Online
Trochu wrote:
My boot cover is just about complete...
Any pictures of progress to date?
Cheers, Tom
PostPosted: November 25, 2021, 10:41 am
That's exactly what I did, had to grind the tip to fit the button recess. Pop rivets are the way to go.
