It is currently June 14, 2024, 5:52 am
 Post subject: Re: Midget 1500?
PostPosted: March 11, 2023, 10:42 pm
Bought the Midget.
Picking it up to trailer home next weekend.
Tires were 10yrs old & didn't want to put faith in them for the 65 mile drive home on the freeway in the dark
Car seems to run well, brakes need some work & a few small leaks to resolve.
Will keep it at my dad's place while we get it roadworthy then bring it home. Gives me time to get a cover built where I'm going to park it.
1975 MG Midget
13B Powered Rotus Geauxkart
PostPosted: March 12, 2023, 11:07 am
:cheers: I'm jealous. :ack:
Agree on the crank thrust bearing clutch press test or you can just push-pull on the crank. Must be a way to retain a loose thrust bearing without drilling to countersink brass screws in the face, then trying to line the holes in the main cap for subsequent thrust bearings. Need a pro machinist imho.
PostPosted: March 12, 2023, 11:12 am
Couple snaps in the seller's garage last night.
Obviously needs a full respray & a could body dents fixed.
Brakes need a bit of work. New MC & rear cylinders, but the pedal takes a fair bit of effort for good braking response.
Cat already deleted & my dad thinks m8ght have an upsized header on it, which is then downsized to the tiny straight pipe to the rear. Sounds pretty good IMO. Not sure about the smog/air pump, lots to learn.
And, the rubber bumpers gotta go.
1975 MG Midget
PostPosted: March 12, 2023, 6:06 pm
Still waiting on my membership on an MG forum to be approved.
Any of you MG pros know if a 175/60-13 will fit without interference on a stock Midget? First this, this toy needs tires. Looks like Kimbo offers the current 155/80-13 & 175/60-13 which are <1mph difference on the road. Need to c9nfirm the spare size & order 5 tires.
1975 MG Midget
PostPosted: March 12, 2023, 7:16 pm
Stick with the 155-80-13. I think the original size is 145-80.
Sprite/Midget: The square-arch rear-fender cars have very restricted wheelwells. Even a 165-section tire is probably going to rub on the back under hard cornering. The round wheel-arch cars have much less of a problem, and 5.5” wheels can be fi tted with wide tires as long as the springs do not allow the tire to contact the fender lip. This led to many a Bugeye that looked like it got mated to a steamroller. Perhaps Austin moved to the square wheel arches specifically to prevent Americans from fitting Chevy Vega wheels with fat, wide-oval tires to their cars.
https://mossmotoring.com/tire-wheel-plus-sizing/
PostPosted: March 12, 2023, 7:17 pm
Thanks, good to know. Now to verify the size of the spare & get 5 tires ordered.
1975 MG Midget
PostPosted: March 13, 2023, 4:13 am
The spare would be a matching wheel so all the same size.
And I can supply you with an unmolested trunk lid if you like, I have several, cheap.
PostPosted: March 13, 2023, 7:34 am
If we decide we don't want the luggage rack, may take you up on that
Shipping will be the gotcha, I'm sure. Unless I can manage a local pickup. My mom lives between Vegas/St George, not sure how far that is from your area
1975 MG Midget
PostPosted: March 13, 2023, 9:30 am
One of the disclosed issues was that there is a tear in the top.
The driver's side 1/4 window is separated from the top in the corner. Think this can be patched/mended, even short-term until we feel like shelling out $500 for a Robbins replacement?
1975 MG Midget
PostPosted: March 13, 2023, 9:53 am
Comes from not hand flexing the top at those window corners when putting it down; especially if it is cool weather. You could probably find a hard top for that kind of money. Here is an affordable soft top:
https://www.ebay.com/itm/185694833663?f ... %3A2047675
PostPosted: March 13, 2023, 9:58 am
Not a bad price, but that's for a B, not a Midget.
Can't tell if it has the retainer snaps or if those have to be installed.
The Robbins, I'd found on Moss Motors. Honestly, if I can repair that separation, it would work. Top would be down anytime the car's moving, would just need that in the event of rain while parked away from home.
1975 MG Midget
PostPosted: March 13, 2023, 10:08 am
https://www.ebay.com/itm/295527717332?f ... %3A2047675
PostPosted: March 13, 2023, 11:04 am
Couple hundred cheaper than the Robbins, and since it'll very rarely see anything but a sunny day, don't need a super premium lid.
1975 MG Midget
PostPosted: March 16, 2023, 9:39 am
My spitfire has a hard top, but I will also be fitting one of this suppliers soft tops. :cheers:
PostPosted: March 16, 2023, 11:00 am
Glad for the endorsement :cheers:
1975 MG Midget
