Wishbone suspension analysis program by MCdermott
junior
Problem solved. Its all good!
Sold: GT30/71R My00 S2k
chetcpo
- Building: positive attitude
Yup, for any other Miata spindle users faced with this quandry, just get the distance from your lower balljoint center to the chassis centerline to 26.3" and your front track will match your rear.
- dhempy
- Man of Constant Hazard
- Building: 1.6 Miata 442
- Contact:
Auto-X Fil wrote:Uh, yeah. I have 0.007" over 2" of bump and 0.020" over 2" of droop. And my numbers are kinda lousy because I am not shortening the Miata rack for my +4. I'd say the very most you could deal with would be 0.1" at 2" droop, and half of that at 2" bump. Even then it's probably going to be palpable.
I've got my rack apart now, ready for chopping. That won't happen for a week or two (AT LEAST) until I have the suspension designed.
But I've got to say, shortening the rack and lengthening the tie rods is a bit intimidating. I'm very interested in your design, Auto-X Fil. Could you post your dimensions? Better yet, how about attaching your .WSH file to a post? I'd be very interested in a design that didn't require cutting the rack, but had good bump steer qualities.
-dave
- dhempy
- Contact:
Re: wishbone program
JackMcCornack wrote:The way Mazda does it (and I do also on my own Miata-based cars) is put the front pickup point for the lower control arm behind the steering rack, and make the rack the same width as the pickup points, and the tie rods at right angles to the direction of travel (that is, the tie rods are parallel to each other when viewed from above). Zero bump steer when going straight, minimal bump steer when bumping and turning.
Can you post some photos of this, Jack? Have you run the numbers through Wishbone?
-dave
chetcpo
The only way to achieve no bump steer is to shorten the length of your A arms to that of the stock Miata. I took nearly 6" out of my rack and I would've liked to have taken more, but that's all I could get without cutting into that big ol steel slug that goes in the end of the Miata housing.
What Jack and Mazda did was move the front lower suspension pickup back behind the steering rack. Imagine you are looking from above at the rack in place between the two uprights. Now imagine putting the front lower suspension pickup just behind the steering rack and the rear lower further back.
bluej
chetcpo
bluej wrote:good morning fellow locosters.
does anyone have a complete set of measurements of a miata's suspension? i've done a bit of searching to no avail but it seems highly unlikely that this info isn't allready out there floating around somewhere.
http://www.locostusa.com/forums/viewtopic.php?t=1409
bluej
chetcpo wrote:bluej wrote:good morning fellow locosters.
thank you VERY much! that's exactly what i was hoping for!
- Blackbird
- Weight watcher
- Building: R1 powered Locost
- Contact:
chetcpo wrote:Yup, for any other Miata spindle users faced with this quandry, just get the distance from your lower balljoint center to the chassis centerline to 26.3" and your front track will match your rear.
I'm a little confused.
As I've read your message I was thinking to myself "wouldn't you want to have a wider front track than rear?", so I decided to check what Mazda did and found the specs of the 95 miata online -
FR track 1407 mm
RR track 1427 mm
And also the 99 miata -
FR track - 1405 mm
RR track 1430 mm
Hmmm
Moti
chetcpo
Blackbird wrote:chetcpo wrote:Yup, for any other Miata spindle users faced with this quandry, just get the distance from your lower balljoint center to the chassis centerline to 26.3" and your front track will match your rear.
FR track 1407 mm
RR track 1427 mm
FR track - 1405 mm
RR track 1430 mm
Hmmm![]()
Moti
I think that it's pretty commonplace for people to have a wider front track than rear. Isn't the caterham csr 2" wider up front? I said what I did because many people want their front track to match the rear for aesthetics.
chetcpo
- davew
- Building: 4age locost
Track widths
If you Look at most track dims the front is almost narrower the the rear.
Most vehicle have a shorter front track, The shorter width front track leads to understeer which the auto makers design in to make it safer for the average Joe. But I guess an average Joe does not buy a sport car??
2nd Changing the front suspension geometry just so you do not have to shorten a steering rack would seem to require a lot more effect then the 2 or 3 hours to cut the rack and the $30 bucks to machine it.
Make the geometry right and mod the rack Dave.
- RandyBMC
- Building: Haynes Miata 7
- RandyBMC
