Update: 8/2/08
I drove the car more today including 1 reasonably hard acceleration (hard enough to spin the rear wheels anyway). In the process I broke my tack welds on the fuel tank. I welded it back on with my brother standing there with the fire extinguisher in case of accidental special effects.
A bunch of stuff broke the first time I drove it. I found that the coolant wasn't circulating. The engine kept cutting out after a couple minutes. My fuel pump committed suicide. The fuel pump was a new model bosch but was un-take-apartable. Went to a junkyard and got a cheap pump for $15 which they assured me would work. Which it didn't. Fortunately it was the crimp type, so I pried apart the fuel pump and discovered that one of the magnet brackets was somehow bent into the vanes of the stator. Bent it back but got confused about the orientation of the pump mechanism. by the way, if you guys ever want to see a really beautiful mechanism, take apart a fuel pump. It took taking the pump apart twice in order to figure out the correct orientation of the pump mechanism.
Then, we tackled the fuel pressure issue. Before, I was running the pump --> fuel pressure --> fuel filter --> fuel rail --> injectors. After looking at the honda dealership at the fuel pressure regulator, I had one of those moments where all became clear and I understood how the fuel pressure system works. On some cars, there is a fuel return line from the fuel rail. On the honda k20, the fuel pump and return lines are inside the tank. So is the pressure regulator. Therefore, the fuel pressure regulator (in the honda) maintains a constant pressure inside the internal tubing in the tank. The pump keeps a loop of fresh gas flowing at 50psi. The engine only takes a little bit off that loop.
So I'd been trying to figure this out for the past week or so. So the final setup, including a "water pressure" gauge from home depot is:
Tank --> pump --> FPR --> tank and pressure gauge --> filter --> fuel rail.
Not having this setup was the reason that the first pump died...it was running against a blocked pressure and stalled.
So that's the story of the fuel system.
Coolant wasn't that much more complicated. I got a 11" reversible fan off ebay that seems to work great. My dad removed the thermostat from the engine while it was cold and we jacked up the front of the car around 2', raising the radiator above the engine. Then we filled the water until the whole system was full as best we could tell. I used the obd code reader to tell the coolant temp. When I ran it yesterday, the temp went to 98 C or so...today it hung around 80 C. So I think coolant is working.
JonW or others with honda immobilizer problems...send an email to Edgar at
qfactor85@hotmail.com. He reprogrammed my ecu to pair with the immobilizer and matching key for $100. However, Jon, I believe that you only need an immobilizer key cut and programmed to match the immobilizer. This (at my dealership) is $50 if you bring it in. It's more if you call a locksmith, but they'll come to you.
I'm gone next week to go canyoneering in Zion NP. When I get back I should have the muffler/o2 bungs/ other fuse box and can put the rest of the exhaust together. Reverse engineering is fun, but not that reliable.
Since I'm pressed for time, I don't think I'll be driving it that much. Now, with the engine running, I need to finish adding all the parts and bodywork with tack welds. Then, I rip everything apart, put on some por-15, and reassemble. Then I get to drive :p. (And register)
For those wondering what it's like to drive:
Acceleration: scary. I haven't gone above 1/2 throttle and I got wheelspin in 1st.
Braking: reasonably fast. I don't have much of a standard of comparison. Braking effort doesn't require a strong leg at all.
Steering: instantaneous. When you move the wheel, the car jumps instantly. This seems to be the biggest difference between this car and everything else I've driven. Steering effort at low speed is fairly high. I'm still dealing with the problem of not enough caster. What really bugs me is that the centering works when moving in reverse. hmmmm
Suspension: stiff. But what would you expect? Body roll is undetectable in the light turns that I've done so far.
Grip: I haven't done any really tight turns at speed yet.
