FWD "Mid-engine" Locost....?
Got an idea that's not quite ready for reality? A better way to build a better car, but you're not building it yet? Post your ideas here!
RoHorn
Post by RoHorn »
Have been wondering recently how well an FWD build with the transaxle ahead of the engine, sort of like a chopped & channeled mini-Cord 810/812, would work and look. I'm guessing one of those Subaru engine/transaxle swap kits intended for VW rear engine conversions, but used at the front of the car, would work rather well. Yes, it would take a fair amount of re-design, which could be fun...
Part of the motivation: There are a LOT more Imprezas out there than the traditional donors - I'm a few decades too late for a traditional build.
I'm also wondering if this has been done before. I vaguely remember reading something somewhere ("Lotus Seven & The Independents" book? No longer have my copy...) about a 7 spinning the front tires after a surprise snowstorm at some 7 gathering.
Mid-engine RWD with a Subaru engine/transaxle already done (Factory 5 "818") - might scale up the Terrapin Mk5 plans to make my own...
Miatav8,MstrASE,A&P,F
Re: FWD "Mid-engine" Locost....?
I don't see any net gain/advantage to doing this. A fwd ifs donor can be repowered with a diff and a bike motor for less effort.
Custom gear sets for flipping a transaxle around the other way are very expensive and may not be available for future replacement.
If you wan to have fwd with the transaxle in front of the engine, take a vw bug type transaxle and build with it at the front with custom uprights or appropriate to the cv joint early vw fwd uprights.
The factory five came from a guy who built a one-off called the Blast. Only downside imho is the transmission sticks out past the rear wheels.
RoHorn
Post by RoHorn »
Good points - thanks.
Initially thought about it after seeing a cheap Vanagon come up for sale not too far away - and wondering what could be done with it. Then I found out that replacing the entire drivetrain with Subaru hardware is common enough to support an aftermarket. But the VW drivetrain is still an option, even if I'm trying to get away from older hardware.
That - and wondering what the vehicle dynamics of an FWD car with far lower and centralized mass than normal might be like - and liking the idea of a front engine sports car without the transmission and driveshaft taking up cockpit space.
I recall the subbie custom ring and pinion comes from Australia but I've not been following that very much. VW busses are in high demand by folks world wide with lots of cash so it might make sense for them.
The original vw transaxles for busses are strong but don't have many options for final gearing and only 4 speeds without overdrive. Original gearing is "farm tractor" low due to the power to weight of the busses. I had a '70s one.
Chris in PA can answer what that would be like. He used a vw engine up front with a torque tube (less interior space lost than using a driveshaft) and a porsche transaxle at the rear: viewtopic.php?f=35&t=13200
RoHorn
Post by RoHorn »
Will have to study the VW possibilities some more - thanks for that link. The Subaru option has far more potential, but it would also cost an awful lot more. I don't want to fall into the "For $X000.00 more" trap - finished is always faster/more fun than unfinished.
Had a VW Thing as a daily driver back when they were dirt cheap - almost 40 years ago. Just started searching for Super Beetles, which used to be cheap and unloved - even those are getting more expensive. I didn't know I was that old...
Sam_68
Post by Sam_68 »
RoHorn wrote:Have been wondering recently how well an FWD build with the transaxle ahead of the engine, sort of like a chopped & channeled mini-Cord 810/812, would work and look.
It's been done at least twice that I can recall off the top of my head, here in the UK (I'm sure there are other examples that I can't bring to mind at present).
One was a car called the Brooke 245, which was a tandem 2-seater:
The other was a one-off special called the JNS, styled to look like an old Alfa Romeo Alfetta 159:
Both are based on old Renaut 5 components; both worked well (the Brooke 245 was sold in kit form and was reviewed favourably by the UK kit car press), and both obviously used the Renault drivetrain to take advantage of the fact that you could achieve a 'front mid-engined' layout without the need for a propshaft, so you could have a centrally seated driver sitting down low.
The Brooke was also offered as a 3-wheeler (and there were several other 3-wheelers - the Kindred Spirit and DRK come to mind - that used the same drivetrain)
KinFung
Post by KinFung »
dont forgot this 8) :lol:
Sam_68
Post by Sam_68 »
KinFung wrote:dont forgot this 8) :lol:
I'm not sure it qualifies as 'locost'! :D
Warren Nethercote
Post by Warren Nethercote »
Don't want to show my age but many, many years ago Jim Hall wrote an article or a series of articles on handling in either R&T or Car and Driver. He paid a lot of attention to slip angles and seem to demonstrate that RWD was the way to go if ultimate cornering speed was your goal. Not to say that a front-wheel drive (fwd or FWD?) locost wouldn't be fun, given big enough front tires. But suspension geometry would be critical. I'd suggest a front deDion axle but apparently Posie's (?) both-end deDion axle SCCA (CanAM?) sports racer suffered terribly from gyroscopically-induced bump steer. Maybe apocryphal, or simply bad memory, but a matter for caution.
Warren
TRX
Building: Locost variant
Post by TRX »
Sam Posey was the guy who drove the beam-axle car. Last time I looked there still weren't any useful details about it that I could find.
I've seen the "gyro" and "bump steer" comments elsewhere, but considering that beam-axle racing cars were hitting over 150mph before independent front suspension became fashionable, and there are modern off-road racing trucks that go about that fast, I'm dubious. I've also driven heavy trucks on what passes for local pavement, sometimes over 80mph, and their beam axles didn't do anything untoward.
It's possible Posey's car was a bad design, or had a bad setup, or the whole thing could just be net.lore, like the reviews of the "terrible boost lag" of a car I used to have. Nobody who drove it noticed anything unusual; perhaps not being automotive journalists meant they were less discerning about it. [sigh]
KB58
Building: Midlana
Contact:
Post by KB58 »
I'll offer this up if the OP isn't already aware, https://midlana.com/, but as this thread is 2yrs+ old, I wonder what he chose to do.
Shuzo
Building: lurker
Post by Shuzo »
I too am curious. RoHorn has built some very interesting racing motorcycles and was working on an engine design for a while.
I have been looking at the SAAB Sonnet III, the early 1970's German Ford V4 in the front wheel drive Sonnet type 97. Parts of the car look fine, especially the rear hatch and the cockpit. The front with it's gargantuan overhang leaves me peeved. A contemporaneous competitor to what became the Sonnet II was the Quantum built by an MIT affiliated racer. While the SAABs type 93-97 had from front to back, engine, differential, gear box, the Quantum drive train was reversed using SAAB gearbox, differential and three cylinder two stroke.
Inspired by the beauty of the Quantum and my affection for the hatchback of the Sonnet III, reversing the drivetrain of the Sonnet would reduce the front 62%/38% rear weight distribution, lengthen the wheelbase and reduce the height and length of the front overhang. Then the Sonnet III would look like a nice car!
Many Renaults, the R4, R16, R5, R7, R14, the Citroen Traction Avant, the DS and SM had the engine behind the front axle and the gearbox in front. Alas, all those cars are old. The last gearbox to the front drivetrain ceased production in France or Spain in the mid 1980's. The R16 transaxle was in the Lotus Europa, and is easy to reorient with no machining.
Are there more modern transaxles that can be inexpensively modified for gearbox first layouts? The Subaru reorientation done in NZ is about $5000 as I recall, before tariffs...
David_dat75
Building: car
Contact:
Exploring Alternative Engine Choices for Builds.
Post by David_dat75 »
I believe that using unconventional engines can significantly enhance the uniqueness and performance of a build. What if we started embracing even more radical options, like electric motors or unconventional hybrid setups? Could this shift redefine the essence of classic car culture, or would it alienate traditionalists?
The Science Behind Cold Immersion Therapy: progorki.com
