violentblue wrote:
Not quite a 7, but there will be some interesting crossover material.
And that’s why I appreciate so much you guys sharing your forum with me!
sodamninsane wrote:
so your picture begs the question......... is it level?
<snip>
why not just use the factory front spindles from the SHO?
Ha. Yea it’s level. Both axially and whatever the complement of that is. And yes, so is the car. I put the car on HF jackstands and then leveled those up with thin steel shims until the pinch welds on the bottom of the BMW were all level. Everything is getting installed level to those and square to a string line down the center of the car.
There are many reasons I chose to use the Miata rear spindles:
* The sho was 3500# and my 332ls will be 2500# so the sho brakes would be overkill.
* I needed to shorten the sho axles anyway or the whole thing would have looked goofy wide so there’s no $ savings there.
* The sho front stuts were shot and I would have needed new springs anyway so there’s no $ savings there either.
* Because the sho struts are huge compared to coilovers so fitment would have been more of a challenge and the rear track would have to be wider.
* Because I drove a Spec Miata race car for 3 years and I’m spoiled by *great* handling.
* Because I want a short/long A-arm suspension.
* Because I want to experience all the fab work.
* Because the sho hubs weigh more than a tungsten brick sh!thouse.
Peter
