wheel hub assembly
arbalest
Building: hi perf sidecar rig
wheel hub assembly
Post by arbalest »
I'm looking for a bolt on wheel hub assembly with the following specs:
Wheel pilot dia.: 54mm
BCD 4x100
flange offset: <50mm (flexible, though)
I have searched, but not having any luck.
Anyone here know of one?
Miatav8,MstrASE,A&P,F
Re: wheel hub assembly
Yaris rear.
arbalest
Post by arbalest »
Thanks!
samlevy0515
Post by samlevy0515 »
Have you checked with SKF or Timken's catalog? I know they list assemblies by hub bore and bolt pattern — might find a match there.
Precision in motion, powered by servo motor technology.
arbalest
Post by arbalest »
I bought the Yaris hub. Everything looked good until I tried it with brake disc. Studs are 14mm. Wheel uses 12mm studs.
horchoha
Building: locost super seven
Post by horchoha »
Could you not change out the studs?
I found yaris studs to be M12-1.50. You can build the upright to work with the wheel,tire, and a 1/2 inch spacer/adapter if necessary but the studs can probably be swapped (let me know if you'd like a reference). What are the wheel specs? Part number for the hub?
Users browsing this forum: Semrush [Bot] and 6 guests
