Gipsy Danger (442 Miata)
scott322
- Building: locost 7 442 frame
First car build using the 442 frame plans. Found a few 90's Miata's local so its going to be a pretty basic build.
viewtopic.php?f=35&t=25146#p276391
442 Frame, 14 ga.
Donor 1991 Miata BRG 117K 1.6L 5speed (car was totaled when a tree fell on it)
Norwich, CT
442 Frame, 14 ga.
Norwich, CT
Bent Wrench
- Building: autox Volvo 220
- RTz
scott322
Gipsy Danger
Few more tubes added. Overall the layout and keeping everything strait wasn't to bad. I'm building directly on my concrete floor which is really flat because its been repaired with a thin coat of self leveling cement. I had some hiccups with the rear bulkhead. The top rear tube (O) was not landing in he correct location, and stupidly I tacked it into place assuming the print was wrong. It was still bothering me the other day so I sketched the frame up in CADD and verified the print is correct and my frame is wrong. After a few measurements I discovered I cut tubes K1& K2 an inch too short
. This caused the angle of the rear bulkhead to be more vertical than it should be. I'll have to cut it out and replace the tubes, I don't want the rear bulkhead that steep.
4k build log is on my YouTube channel.
https://youtube.com/playlist?list=PLOHq ... n9NYYlspBV
. This caused the angle of the rear bulkhead to be more vertical than it should be. I'll have to cut it out and replace the tubes, I don't want the rear bulkhead that steep.4k build log is on my YouTube channel.
442 Frame, 14 ga.
Norwich, CT
442 Frame, 14 ga.
Norwich, CT
- trialsmangasgas
Re: Gipsy Danger
Scott322, congrats on starting. You might want to put you location in the avatar. That way if there is someone near you they might be able to help out. Russ
ps: nice garage and tools!!!!
- horchoha
- Building: locost super seven
Re: Gipsy Danger
Yes, location please, and lots of pics!
Congrats on starting the build
- rx7locost
Re: Gipsy Danger
Welcome to the madhouse. Looks like you are on your way. Keep at it, a little each day and week by week. Pretty soon, you'll be driving.
- Lonnie-S
- Building: V6 Powered Locost
Re: Gipsy Danger
Good catch on the short tubes. Better now than in 6 months!
scott322
Re: Gipsy Danger
1991 mazda miata. Payed $1300 non running. Has a broken timing belt so it was parked. While parked a tree crushed it a few months back. Has 110k and was a good runnig car before the belt snapped. I have the front timing cover off and everything ready to slap on a new timing belt, just waiting for it to arrive.
442 Frame, 14 ga.
Norwich, CT
442 Frame, 14 ga.
Norwich, CT
- JackMcCornack
Re: Gipsy Danger
Whoa, Scott! Good thing that timing belt broke, or somebody might have been in it!scott322 wrote:Has a broken timing belt so it was parked. While parked a tree crushed it a few months back.
- JAMADOR
- Building: FC RX7 Based
Re: Gipsy Danger
Saw the photo before reading the description. Glad it was a tree & not a rollover.
1975 MG Midget
13B Powered Rotus Geauxkart
JPS Europa
- Building: 4AGE McSorley+4
Re: Gipsy Danger
Great pick of donor. I wish I had gone a single car donor when I built mine. It would have saved so much time. There are several completed build here in the Northeast if you ever need to see what someone else has done.
Paul
Paul
scott322
Re: Gipsy Danger
Got the timing belt installed without any issue. Having some issues with the car starting then shutting off. Seems like something in the ECU is shutting it down. I have to go through the fuel system, but over all it should be a solid donor car.
https://youtu.be/wKBb3s0mDKs?si=L7h1K898xSa5vGtp
442 Frame, 14 ga.
Norwich, CT
442 Frame, 14 ga.
Norwich, CT
- Miatav8,MstrASE,A&P,F
- Automotive Encyclopedia
Re: Gipsy Danger
Check your vacuum line connections hidden under the intake/throttle body at the iacv and on the mech iac servo on the side of the plenum topside. You could use a paper clip between the GND and TEN pins in the diag box to keep the iac from functioning but it sounds like it is working fine but with vac leaks. If you remove to clean, be very careful with the molded multi-hole o ring that can be pinched and ruined when putting it back together.
Don't do it just yet, but some deactivate/remove the iac if a new one is needed since they are very expensive but if you operate in cold weather, it is needed to drop the idle once the engine is warm or use a dash pot.
Nice lathe! Perfect size imho.
Bent Wrench
