It's been almost a month, but all my real world chores are done now, and I can get back to my Locost.
I had been changing things fast and furiously in terms of the front suspension brackets and suspension geometry when I left off last. My first task was to make sure I was working with the latest data, and all the data from various sources like the suspension analyzer software, my notes and the brackets themselves all matched up, apples to apples.
Once that was done, I restablished the lower, chassis-side, A-arm brackets to a close approximation to my 3D model. I can make that work. Then I tried some general configurations of the upper brackets using what I had made already, just to see if I could make those work. They're not a good match, but I at least verified I could place the upper brackets at the desired height to get my roll center down to near 1" off the roadway.
I'll need to come up with a modification of what I have on hand now. I think I have an idea. The rear, upper bracket is going to be an odd one, but my idea might simplify placement, yet be simple to put in correct alignment.
The front upper is sensitive to fore and aft location due to the nose cone. I think we're good. I'm going to make the upper brackets smaller than the ones shown here, which will look cleaner and place easier.
Fortunately, the front lower bracket looks pretty good. I can move it forward a little bit, which I may do to make it possible for the steering rack to move forward a little as well. My steering rack has arrived, but I haven't even taken it out of the box yet. I can't really fit it out until the suspension brackets are finalized.
I did discover one little issue. My build table top has gone out of level. Thay may muck up my jig making, but I'll see if I can fix it. If not, I'll align the suspension brackets to level, which might give me 1°-2° anti-dive. Meh! It won't kill me.
