Hey Newt..
The lessons learned from my T5 experiment were these: It will 'technically' work, and on some level it's worth the effort.. In my case the input shaft was slightly bent which gave me an intolerable vibration, but other than that, it was a sound design.. It was initially really nice to have an integrated reverse and .73 overdrive
It did end up proving to be a bit of a redundancy however with all of those gears (6 bike gears + 5 T5 gears) from which to choose.. I found the VFR motor wants to be up past 5K at least to make any power, and the T5 gear spread was such that eventually I left the T5 alone, and did all of my shifting through the close-ratio VFR tranny (truth be told the VFR box was simply more fun to shift/drive.. using the T5 always felt slow/lazy).. It was at that point that I ditched the T5.. Pulling it removed my self-inflicted vibration issue, and it also removed 70lbs from the car (it was also at this point that I the car 100% needed a Guibo, so I was up for a redesign anyway)
.. I came to rationalize that I didn't really 'need' reverse (you don't on a BEC, it's just nice to have)- and I never looked back..
I can't remember all of the details, but I think at that time I was still running a Miata 4.1(?) diff, and it was way, way off for highway use.. In the end, with the VFR / 7.5 diff / and 20" tires, I settled on a 2.73 ring and pinion.. It seems most BEC guys end up around 3.0/3.1 at the diff, depending on tire size and intended use for the car..
That T5 will work as you're planning, it's just a matter of what you want/expect from it..
--ccrunner
Thank you for the valuable insight! I hope it ends up being a good thing. I'm kind of picturing it as like an autocross gear and a track gear. I'll pick one in the T5 but all shifting will be done with the sequential transmission in the Hayabusa engine. I'll probably be in 4th most the time unless someone revs their engine at me at a stop light... Then it's on.
I've attached some of my numbers below. I know sometimes it's hard to decipher other peoples Excel sheets but it makes sense in my head. My goals are to have a 1st gear that will absolutely rip and a tolerable cruising RPM at 70MPH.
