Miatav8,MstrASE,A&P,F wrote:
Fab a fine hardware cloth screen cap then pack some steel wool or fiberglass in the pipe and test.
Install the cap screen with the ends tucked into the pipe then use set screws through two sides of the pipe.
You can insert a steel tube in the center that extends deeper than the packing so it is unobstructed. Tack at the rear top and bottom then drill a couple holes through the 1x3 on the bottom to plug weld the tubes forward end in place.
I'm intrigued Miatav8, but I'm having a hard time picturing what you're trying to explain.. (For lack of clearance reasons, I'm working with a rectangle exhaust at 1x3")...
If you have the time and interest, could you draw/paint what you're describing?
Thanks-
--ccrunner
Dean
1963 Volvo P1800 Restomod
http://locostusa.com/forums/viewtopic.php?f=36&t=163091959 Berkeley SE492 Restomod...
viewtopic.php?f=36&t=19397"ccrunner's 1960 MGA coupe Restomod" found on MGExp.com
