MV8, Nice looking switches, even if they aren't 30A. I too am hesitant on the ebay no-name switch ratings. I want DPDT rockers for my power windows. I'm not sure if I'll rely on the switches alone for current capacity or add relays.
For the cruise, I ended up buying the below switches. The power switch is latching, the other two for set and resume are momentary. The power-switch backlight will light up with the power switch latched on. The other two backlights will both light up when the cruise is active. I read somewhere if both set and resume are pushed simultaneously, then the GM cruise will deactivate as if the brake had been activated. It will still hold the speed in memory. I never heard of that. That possibility changed my thoughts from a momentary rocker to the individual switches. Time will tell if my cruise module supports that function.
I'll call this inquiry complete!
Visit my ongoing MGB Rustoration log:
over HEREOr my Wankel powered Locost log :
over HEREAnd don't forget my Cushman Truckster resto Locostusa.com/forums/viewtopic.php?f=36&t=17766
