S10 Donor Info - Brake/Diff
Potential donor discussions and troubleshooting, gas, diesel, electric powered builds etc..
davew
Building: 4age locost
Re: S10 Donor Info - Brake/Diff
Post by davew »
Geoff
My old S-10 shop manual say
The UBS is the axle ratio code
The C is for the Buffalo plant
The 293 Is the julian Date
The 1 is 1st shift
The 3.41 is the standard ratio for the "s" truck.
Dave W
geofffinlay
Building: MCC-7
Post by geofffinlay »
Dave,
You're a peach. Thanks for the info. I'm assuming that 293 is Feb '93.
Geoff
davew
Post by davew »
293 is the 293rd day of the year.
Dave W
geofffinlay
Building: MCC-7
Dave,
Without your incredible attention to detail, we'd all be lost out here :roll: It's nice to know what day of the year it was made on, but what year was that?
Geoff :mrgreen:
davew
Post by davew »
Geoff
Can't tell by the casting numbers, Typical there is a steel tag attached to the upper RH bolt on the axle cover. That my give an indication, or it can be traced by the serieal numbers on the ring gear.
Dave W
geofffinlay
Building: MCC-7
Dave,
I saw where the tag was. Just a little piece left under the bolt. I do have the diff out so I'll take a look at the serial number on the ring gear.
Cheers
Geoff
Dave1976
Building: LoCost-style custom
Post by Dave1976 »
davew wrote:Geoff
The 1 is 1st shift
Dave W
That should be 3.42:1, and what ratio was standard depends on year, engine, trans, 2wd or 4wd, and tire size ordered. 3.42 was fairly common, possibly the most common, but getting the later 28-spline shafts is more important than getting any certain ratio, ratios are cheaper to change. The other concern is width, 4WD assemblies are wider than 2WD, by about 2" per side, 4" overall.
Dave1976
Post by Dave1976 »
I'm fairly certain i have posted this before, but the S-10 using the same basic axle as the Camaro majes brake interchanges relatively easy, and most of you would probably be happy with the rear brakes from a '98-'02 Z28, or on ReX i used the calipers from an 84 Trans Am, with a new pair of 11.3" x 1" rotors, and modified the backing plates to move the calipers out 0.4"
For even more brakes, '76 Eldorado calipers and late '70s Corvette rotors offer 12" x 1.25" brakes that fit inside 15" wheels. You just need your own caliper mounts.
I would still use either of those calipers even if i went to 14" rotors.
mckwrench
Building: Locost 7+1
Post by mckwrench »
[quote="sytyguy"]Just thought I'd help clear up a few things about S10 donor parts (specifically brakes and rear ends.)
BRAKES
- 97 and earlier S/T axles had drum brakes, while 98 and later had 11.5" disc brakes.
- Also, one of the great things about using GM parts is that SO much is interchangeable. For the S/T trucks you have the luxury of being able to use F-Body (Camaro/Firebird) and some Y-Body (Corvette) stuff when it comes to brakes. That said, a common upgrade for S/T trucks is to use the 98 and later F-Body rear discs (which bolt right up and only require modifying the parking brake cable) and upgrade the front discs.
I admit I havent looked at it real close, but I supposedly have a '99 S10 xtreme rear end. BUT it has drum brakes. So is it really a 99 then? Or an extreme? Or were disc brakes just an option that the donor didnt have? In any case Id like to do a Lowcost disc brake conversion. SYTYGUY, are you telling me that F-body rear discs and calipers will bolt up to my rear end? Am I understanding that correctly?
horchoha
Building: locost super seven
Post by horchoha »
hey mckwrench
Check out his sytyguy's profile - the last time he posted was Aug 2010
mckwrench
Post by mckwrench »
Good catch Horchoha, my bad. That's what I get for staying up past my bedtime. I should have directed the question to Dave1976
