So Midlands frame skinned with a chopped up Nissan nx2000
Got an idea that's not quite ready for reality? A better way to build a better car, but you're not building it yet? Post your ideas here!
jere
Building: Katana based somethi
Post by jere »
So I've been hooked on the idea of skinning a locost-esc (midlana) frame with a body/outer sheet metal from a production car (a Nissan nx2000).
The other benefits I see being areo, registration, the fact that there could be a roof and just the Nissan fanboy/middle (aged man) geek factor.
I ve spent the last few years assembling tools and the wife took the kids and walked out of the marriage... Still have the derelict rusting, somewhat hopped up pre marrage Nx in the garage...(getting into the stuff with her lawyer soon not 100% sure where it will end up) Kinda feel bad about cutting into the old project car but I think the end result might be more fun.
I am thinking about ditching the remaining glass for lexan and making the front and rear sections each their own smaller, lower, all one piece sections. Doors morphed into permanent side panels and so on just leaving a loose resemblance to the original. But doing all this after the frame is built... I think
Is this far fetched , should I just stick with a simpler design for doablity/sanity?
carguy123
Building: Choppercrosser
Re: So Midlands frame skinned with a chopped up Nissan nx200
Post by carguy123 »
jere wrote:Is this far fetched , should I just stick with a simpler design for doablity/sanity?
SANITY? HERE?
KB58
Building: Midlana
Contact:
Post by KB58 »
It may be better to start with an ex-GT5 race car. That would give you the tube frame and body, then modify to your heart's content.
jere
Post by jere »
SANITY? HERE?
Yeah I had a feeling that wording might be called into question :lol:
jere
Post by jere »
KB58 wrote:It may be better to start with an ex-GT5 race car. That would give you the tube frame and body, then modify to your heart's content.
Yeah starting with an existing frame sounds considerably more sound an idea... Especially coming from the designer of the frame I was planning on using... :|
But tube frame and gt anything sounds way out of my price range too. Should've mentioned that too I guess too. Going for inexpensive as possible and diy as much as is required.... I think. I'm a more time than money type.
On the tube frame cars I've seen naked, it doesn't seem to me there is much more than an odd tube here and there to support the panels. Like the bumper cover support in the photo below
What are the biggest set backs that I have set myself up for so far that you see Kurt?
jere
Post by jere »
Oh also forgot, I have another potential donor an ion redline with the super charged lsj ecotec.
There absolutely no attachment to it other than that it holds a good amount of groceries. Cable shifter instead of rod based, and it has some good donor seats... Downsides are that it is obdii and has two computers that hate mods, and it currently has way less power than the nissan (the Saturn is in the neighborhood of 210 HP the nissan is closer to 300), and no form of lsd at all
KB58
Building: Midlana
Contact:
Post by KB58 »
[imghttp://www.carbuildindex.com/wp-content/uploads/2013/09/403.jpg][/img]
Well, of course I'd like you to build a Midlana, but what you're looking to do, it seems easier to start from the "other end" of the design, where someone's already done the heavy lifting. About cost, find one without a drivetrain; I've seen such cars for well under $5k.
jere
Post by jere »
KB58 wrote:
Well, of course I'd like you to build a Midlana....[snip]
Good that's all the validation I need, its settled then! 8) :P
....I will have to keep an eye for deals like that as a fall back :o
I still have to clear out the garage and make a build table and wood frame mock up. Maybe reality will help with my decision process after that.
Great books btw, I ve really gotten a lot of good direction out of them.
jere
Post by jere »
http://www.jegs.com/p/Alston-Race-Cars/Alston-Pro-Gas-Chassis/2392931/10002/-1
So stumbled across these Alston tube chassis... Anyone have any thoughts? How do these stack up to the raw costs of diy locosts
jere
Post by jere »
Drove past this in the cab the other day... And started thinking about how it would look/fit as alternative skin donor :D
RichardSIA
Building: Dio Tipo
Post by RichardSIA »
Anything Porsche is now crazy priced. :shock:
Even the glorified Bug in your pic.
Not sure where you are, but a LBC like a Spitfire or GT6 would be a lot less money and probably a better project fit so long as you can live with a front engine.
If Nevada is not too far away I can help with that. :lol:
ngpmike
Building: Granny Flat
Post by ngpmike »
OK, Richard... you're gonna have to translate this one for me! "but a LBC like a Spitfire or GT6"? Maybe I just haven't had enough coffee, yet! The best I can come up with is "Little Brit Car", but that's just a "guess". Inquiring minds want to "KNOW"! As an OLD hot rodder, my default would be "Little Block Chevy", but that just doesn't sound right! "HELP"!!! :BH:
TooBusy
Building: Locost D Mod
Post by TooBusy »
ngpmike wrote:OK, Richard... you're gonna have to translate this one for me! "but a LBC like a Spitfire or GT6"? Maybe I just haven't had enough coffee, yet! The best I can come up with is "Little Brit Car", but that's just a "guess". Inquiring minds want to "KNOW"! As an OLD hot rodder, my default would be "Little Block Chevy", but that just doesn't sound right! "HELP"!!! :BH:
LBC is Little British Car
Midget, Sprite, Spitfire, MGB, etc
