seattletom wrote: . . . S@ddlez kind of fits alongside t@bs and br@cketz in the locost lexicon of fiddly things that burn up a lot of build time. I think JD would approve of the spelling.
For sure!
 Gavin, the top of the legs are welded to the rings (just tacked for now.) The bottom of the legs will bolt to t@bs welded to the chassis. Two 3/8" bolts per leg. The hoop assemblies need to be removeable so I can install/remove the driveshaft without pulling the diff.Mnot wrote:Tom, are the driveshaft hoops welded or do they bolt in?
seattletom wrote:May also add a strobe effect module to the brake light.
Thanks TRX, I don't need to attract that kind of attention.TRX wrote:Besides annoying other drivers, that'll get you a ticket in some states; mine for one. ($250, last I looked) Flashing lights, other than turn signals or hazard flashers, are prohibited other than for specified police or emergency vehicles.
Lonnie, the Odyssey PC680 battery should have enough poop to kick over the V8. It’s a GM crate motor/ECU combo with a little bit of cam but factory stock. I don’t expect to have to grind on it for too long before it fires up. If the alternator keeps up with the electrical load when running, it should be ok.Lonnie-S wrote:Will that (foam simulated) little battery actually turn over that big V8? It doesn't look too much bigger than a motorcycle battery.
The panel attachment system (floating nutplates, etc.) is borrowed from Martin (mgkluft). It’s nice to have most every panel removable and all the innards accessible.I'll be very interested in seeing how your body panel scheme comes together. I have it in mind to do something similar, but no definite plan yet. I'll be looking to yours for some guidance.
Thanks Andrew. As you know, the devil is in the details.a.moore wrote:Great fab work on all of those tiny details Tom. They're turning out very well.
 One of the joys of using round tubing is having to weld on the br@ck^ts and t@bs.  Square tube has lots of flat places where rivets or nutserts can be used as needed late in the game.  Hopefully, I’ll have welded on most of what I’ll need before painting the chassis.
 Thanks, Larry. Progress has been good, except on a number of domestic projects.benny_toe wrote:You have been keeping the sanity in place by being busy! Good progress. Like the curve in the top piece edges! looking good Tom!
   Paul, glad vaccine is flowing your way. The sooner folks gets jabbed the sooner we all get beyond this mess. Give a holler when you come out to see Matt. It would be great to have a COVID-safe gathering.JPS Europa wrote:You have been cranking on the beast for sure. I am looking forward to seeing it in person again before too very long. Getting my first vaccine shot next Sunday.
