Thanks Bobber for posting your worksheets. I'm still working thru it. Also thanks for the FSAE pointer MO, I need to go read that too.
I'm still looking for the most recent Vsusp work I did for Car9. My suspension has a considerable amount of lateral roll center movement. I did not consider that a priority at the time. Since I did this I asked Rob to add the force lines from the contact patches to the instant centers ( green dashed lines ). I think they are instructive and maybe more helpful than the roll centers. Things like weight jacking are directly evident looking at the green dashed lines, but since the roll center is an average of the two suspension sides, it's not clear to me how you understand this.
I still do not see a direct correlation between lateral roll center movement and changes in angles of the force lines. My front suspension manages to hold the force lines pretty consistently but the rear shows a small increase with roll. That would say the jacking forces are rising while the car is rolling and also the geometric roll resistance. The two suspensions are behaving a bit differently because the roll center is representing an average of the two sides, yet there is not enough weight on the inside tires to matter nearly as much.
What I was trying to do was to make the car tunable by making the rear roll center movement adjustable in it's response to the cars pitch. It could remain nearly neutral or it could move either up or down depending on squat and dive. If it understeered too much on entry or too much on exit - that can be tuned for to at least some degree. The graph is below and it shows how the roll center moves for 3 different length upper rear suspension arms. The upper arm is just a radius rod so a different length is easy. The height of the RC is plotted against bump and droop ( squat or dive ) vs. roll.
Bobber your worksheet is great. To repeat what you are saying, so I understand, you roll the chassis and apply a standard load to the tires and calculate the loads at all the suspension mounting points. Then you can scale those loads according to the weight transfer of the lateral acceleration. And nothing like a lateral location of a roll center shows up in this work...
It's late, I'll look some more tomorrow. Thanks again.
