Beadrolling aluminium sideplates?
Posted: February 19, 2025, 1:26 am
Beadrolling aluminum side plates, have not seen it done, why?
It’s a normal procedure on floor panels in steel to stiffen them up. I was planning to do it on my aluminum floor also, but most for making a good drainage for water to the floor drain hole. (With rubber button in it when normal driving)
But will it make a difference in stiffness on sidepanels.
Welding crossbars is a good step, but will beadrolling a X in the panels help for compressive forces? Or is it just tension forces the plates help for?
