floor panels
HarmalloyX
Building: Grand Prix FWD donor
floor panels
Post by HarmalloyX »
what do yall use for the floor and firewall? i was thinking of using 20gauge galvanized- stitch welded on and some seam sealer.
tibimakai
Building: 442E
Re: floor panels
Post by tibimakai »
I'm using steel sheet metal at the lower part stitch welded, and I will seem seal it, and an aluminum at the top.
Tibor
'20 Alfa Romeo Stelvio daily
Locost/442E in progress
horchoha
Building: locost super seven
Re: floor panels
Post by horchoha »
.062" steel sheet for floor, behind seats, tunnel, and firewall, all stitched and seam sealed.
Research welding galvanized steel, nasty fumes can lead to metal fume fever :ack:
tibimakai
Building: 442E
Re: floor panels
Post by tibimakai »
For everything else I will be using aluminum. 0.90 for the floor, .050 hood/scuttle/dash and .040 for the rest.
Tibor
KB58
Building: Midlana
Contact:
Re: floor panels
Post by KB58 »
As in small aircraft, stainless is recommended for anyplace that fire could occur, since aluminum melts rather easily. Granted, the amount of time the firewall might be exposed to flame is much shorter than in an aircraft, but I figured why not go with the better protecting material.
HarmalloyX
Re: floor panels
i used to weld galvanized for a living. - its true that you dont want to breathe the fumes, but i doesnt do any permanent damage. All you need to prevent the fever is a bit of ventilation. it does give porosity and spatter, you wouldnt want to TIG weld it.
doommachine
Building: lotus seven kit
Re: floor panels
Post by doommachine »
I used A single cut sheet of stainless for the floor, and 16 gauge aluminum for the tunnel. Firewall is webbed 16gauge plasma cut steel with 16ga aluminum face. cabin Backing plate is also 16ga aluminum. Floorboard and cabin back along with some under body forward panels are attached with 3M Panel bond. Side trans tunnel covers are riveted, and top will be removable
HarmalloyX
Re: floor panels
16 and 18 gauge sure is a lot heavier than i remembered it being!
