Sure thing Jesse. I'd agree that its neat seeing how other people do things.
Miatav8,MstrASE,A&P,F wrote:
The header flange is massive compared to the ports. Aren't the ports large ovals?
I would add a another bend to the #1 primary. A 1/4" is not enough clearance.
Nope they're round ports on the Duratec.
Its painful cutting 1/4" on the HF bandsaw. Thats the main reason for so much being left. I still need to remove the primaries from the flange for welding so I may try to bum a real bandsaw with a good bi-metal blade at that point and go to town. There is also the internal EGR port that is covered by the back of the flange. For the amount I can actually remove and not mess up the sealing surfaces versus the time it will take, I may just leave it as-is.
I've been trying to figure out if I have length for another bend and I'm still really not sure. I'll have to do some drawing and see if I can do it without causing interference issues or screwing up my primary lengths. I'd almost rather try to relocate the alternator to the other side or space it out some so the connectors and other stuff are spaced away from the heat.
I'm probably being overly optimistic here, but I've been in FSAE cars where the header was almost touching the back of the firewall and from the front, you could touch it. It was pretty toasty but probably not more than under the hood normally. With my luck, that stuff on a metal shield will probably not be enough to save an alternator.
As far as weight goes Chet, I'm predicting a push. Based on some of the actual bare weights people have posted on here for Duratecs and the 4AGE, the Duratec is a hair lighter (maybe 20-25lbs) but the Miata transmission is a little heavier than the Corolla transmission.
