Removed the plastic push-through bolts holding the fan to the radiator and riveted the fan to the steel edges of the radiator. For the standard Civic radiator, a 14" electric fan works perfectly, with just a tiny bit of trimming at the top and bottom.
Finally got over my wiperphobia. What was I so worried about?
I used a Lucas wiper system from an MGB. It comes with 3 wiper gearboxes, so that you can lose one and still have enough parts for a Seven. At least, that's how it worked for me. I swear, I walked from the lathe (workbench had too much crap to use, so I was cleaning the parts on the bed of the lathe) to go pee on my lemon tree, and when I got back, one of the dang gearboxes had snuck off. I looked for it for 20 minutes, and still haven't seen it after two days.
Anyway, the Lucas system is SUPER EASY to implement. I highly recommend this setup. Cost is fair...new isn't outrageous. I got a motor and three gearboxes on Fleabay for $50. I was going to use the pushrod system from the Miata, but chickened out. Looking back, I'm so glad I did, as that would be a real challenge to get clearance for, and you'd have to come up with robust mounting points for the arm pivots. The Lucas system uses a push/pull cable inside a 5/16" steel brake line. This means you don't need any clearance from your wiring, and the mounts to the scuttle are simple and bullet-proof.
I don't have wiper arms yet. It seems to move a bit on the slow side, but I'm sure it will seem faster with the arms on. I don't have the auto-park working yet. Gotta find a wiring diagram for the wiper motor, overlay the Miata wiring diagram, and run the whole thing through a British -> Japanese -> American translator. The Miata's intermittent circuit almost works. It delays before starting the wiper, but then never cuts it off again. I'm pretty sure figuring out the park circuit will fix that.
I wanted to mount the motor to the scuttle, so you could pull the scuttle more easily. With a traditional windscreen, that's probably worth doing. With my roll-bar-mounted windscreen, it's going to be a hassle regardless, so I just mounted it the motor to the firewall. My welder just didn't have the oomph for the thickness of the Kinetic scuttle. If I ever get over my fiberphobia, I might relocate it. Nah....
Started playing around with tail lights. Wife convinced my my awesome light bar is not enough, since it doesn't *look* like tail lights. I'm about
this close to just slapping some trailer lights on the back. We'll see.
I brought the nasty old Miata tires in the garage to thaw out (12*F currently), so I can unmount them and install my new tires, maybe tomorrow. I had already broken the bead on one, and it had taken on a lot of water. Felt like I was making a margarita as I rolled it into the garage!
Cleaned all the crap out of the car. Cleaned up the garage a little, reclaiming 2 feet of space along side the car. Nice. Oh, and found some trailer lights. Handy.
Took some pix but they're stuck in the phone...I'll try to post them soon.
Next: tail lights, tranny cover, clutch pedal stop, body work, mirrors. Not much else, I think.
-dave "onward" hempy
Visit my
[Locost 7 build log]
