I'm not sure I'm smart enough for this....I downloaded a 14 day demo of OptimumKinematics to test drive and see what it can do. I set up a suspension I had done in Vsusp to do some simulations and I had the great idea of downloading another OptimumG product, OptimumLap, a free lap sim software, to use the track data in OptimumLap for simulation data in OptimumK. Well one can't use the data directly in OptimumK for simulation but after an email to support I got this response
You can’t directly import data from OptimumLap into OptimumKinematics. What may be possible to do is to calculate the roll of the vehicle with the lateral acceleration values coming from OptimumLap and apply a roll motion in OptimumKinematics. To do this you will need some vehicle parameters such as the suspended mass, spring rates, tracks, etc. This parameters will give you a roll gradient that you can use to calculate the roll of the vehicle in a corner. In order to help you define the roll gradient, please refer to the technical papers in our website:
http://www.optimumg.com/technical/technical-papers/Specifically, the papers: Springs and Dampers part 1 and 2 should help you in this. (Please see part number 4 as it makes a correction to some formulas in part 2).
Long story short I tried to work my way through the formulas to get coherent answers but I'm not up on physics and it's been several decades since I've had to do any real mathematics...I'm lost
I made it through the spring rate formulas and added them to a spreadsheet after struggling to understand the difference between mass and weight and how it affects the spring rate, wheel rate, ride frequency, etc. The next step was to try to understand how to calculate roll rates and roll gradients.
I'm hoping someone here who's a bit smarter than me can take a look at the spreadsheet and see if my formulas are even close to being right and the same as the formulas here
http://www.optimumg.com/docs/Springs%26Dampers_Tech_Tip_2.pdf and more important if the data out is even useable, particularly lines 21 - 32
