Caterham Dimensioned Locost
Whether it's a "book" chassis or another variant, FEA talk or roll cage advice that you're looking for, this is the place to talk frame construction.
Moderators: a.moore, horizenjob
Lonnie-S
Building: V6 Powered Locost
Re: Caterham Dimensioned Locost
Post by Lonnie-S »
Thanks again for the clarifying Internet references, Ron.
STranger 7
Building: 442e with ranger V6
Post by STranger 7 »
RichardSIA,
The MGB 7 frames never got off the ground. The shop space never materialized and life got in the way. etc etc
While waiting to start, I started thinking about designing a frame that would be wide enough in front to use a MGB rack without altering it.
( cutting a section out) Probably wind up looking like the 7x or this 7y
Should handle much better than a MGB. It would just look a little odd
Maybe later.
Clearing the space, where the Ranger based frame was built, to start on a series 2 size frame with the triangulation much like the Cat 165.
Ran across this Spridget powered restoration article. May be of some use to you.
http://www.simplesevens.org/2073/2073.htm
Ron
JAMADOR
Building: FC RX7 Based
Post by JAMADOR »
^ That's pretty cool.
Has a lot of 60s Lotus F1 vibe going for it.
