It is a SHO powered Locost built to Mcsorley's +442 plans with 2" removed from the passenger compartment.
A friend provided a 8x4 piece of staging the use as the build table. It is aluminum framed with 1/2" adjustment in each leg.
My build area.
I am using a miter saw with a metal cutting blade and a Hobart mig welder. The miter seems to make good cuts only requiring some quick dressing of the ends with a file.
The lower frame rails are completed. If the rest of the build would just go this quick and easy.
Gene
