Wrapping Wiring Harness
Moderator: horizenjob
- Trochu
- Building: +442E
What would you guys recommend to wrap the wiring harness with? Seems popular options are friction tape, braided split flex wrap, or heat shrink tubing. I'm definitely not going with heat shrink tubing due to the cost, hassle, and lack of access. I've never used either of the other two products. Thinking the friction tape with zip ties on the end would look pretty sharp. I like the look of the braided wrap as well, just not sure how it would look for the corners, I've got a few 90 degree bends.
Trochu Motor League
KB58
- Mid-Engined Maniac
- Building: Midlana
- Contact:
Re: Wrapping Wiring Harness
I like the braided split wrap because it lets you add or remove wires anytime. I don't like the split plastic corrugated stuff as it's highly temperature sensitive and doesn't run around corners cleanly.
- Trochu
- Building: +442E
KB58 wrote:I like the braided split wrap because it lets you add or remove wires anytime. I don't like the split plastic corrugated stuff as it's highly temperature sensitive and doesn't run around corners cleanly.
I've never used it, just taken it off, but agreed on the black plastic corrugated stuff.
Trochu Motor League
waltj
- Building: locost roadster
The friction tape, of which you speak, has been around since before I could open my Dad's tool box.
It does get real messy when exposed to an engine compartment environment (heat, oil and so on).
You might try these guys https://www.americanautowire.com/shop/harness-tape. They have a vinyl nonadhesive product,
which would nicely complement the braided stuff. Their products are at most of the on line speed supply places.
Waltj
Waltj
- rx7locost
I used the braided split stuff on my Cushman. I liked it. You still should tape the areas where a circuit leaves the main run. A propane torch to heat up a putty knife makes a good cutter. Het it up, then just melt your way thru the braid. It seals the ends from fraying.
Friction tape is a no-no IMO. That stuff gets real gummy over time. If you ever have to work on it later...…..OMG!
- Trochu
- Building: +442E
rx7locost wrote:I used the braided split stuff on my Cushman.
How does it do on tight corners? Outside stretch and inside shrink enough that it looks pretty decent?
Trochu Motor League
- rx7locost
A lot of the final flexibility depends on the number and size of wires in the wrap. Also the more the wrap is filled with wires, the less overlap the flaps have for making the curves/corners. Going to a larger size wrap, helps in the tighter corners to keep the wires covered. Here are a couple of in-process pics of my Cushman build showing a corners, loose bundles before running to their final location and the electrical wrap I used on the ends and junctions. I hope it helps you.
- Trochu
- Building: +442E
Thanks Chuck.
What youve done there looks really good.
Trochu Motor League
- GonzoRacer
- We are Slotus!
- Building: Mallock-Locost-V8
- Location: Tallahassee, FL (The Center of the Known Universe)
Mama always said he was the smart one in the family...Trochu wrote:Thanks Chuck.
- rx7locost
GonzoRacer wrote:Mama always said he was the smart one in the family...
Even if that is so, Mama still loves you JD.
She also asked you, "What are you doing in the bathroom for all that time?".
- horchoha
- Building: locost super seven
Trochu wrote:What would you guys recommend to wrap the wiring harness with?
I couldn't find any curling tape so I used black hockey tape, it's cheap and doesn't cost very much either.
FastG
I always use the Self-Wrapping Split Braided Sleeve from Pegasus Racing. It covers multiple sizes as it self tightens around the wire, heat and abrasion resistant. I always have a couple of sizes available.
https://www.pegasusautoracing.com/produ ... oduct=4011
Graham
Graham
- 300D50
- Building: 13B gull-wing ME-RWD
beal
- Building: Lotus 7 CMC
I keep seeing the word braided? Harbor Freight sells slit wire wrap in 3 sizes. It is not braided just fluted and split. A few tie wraps to close it up and your done
- 300D50
This sort of stuff.
