Have not posted for a long time ( 5 years or so ) but now I come with hat in hand ,asking for HELP I'm looking for aluminum extrusion for the wind shield . What is the best profile to use and where to get it from , I'm in Vancouver Canada .
Thanks ,
Steve
Wind shield
- mainlandboy
Re: Wind shield
Below is a chart for some locally available aluminum channel.
Just make sure the gap width for the windshield (A - 2C) is wide enough to accommodate the thickness of the glass and any gasket material between the glass and the channel.
Here is the local supplier:
https://www.metalsupermarkets.com/
The tougher part will be bending the curve in the channel without kinking it.
Here is a local place where I got my custom laminated windshield cut:
http://www.nordelglass.com
Alfasuper7
- Building: Locost 7 Alfa grar
Re: Wind shield
Thanks for the Info,
Steve
Steve
- Miatav8,MstrASE,A&P,F
- Automotive Encyclopedia
Re: Wind shield
I second getting the channel at the glass shop. The best channel is increasingly hard to find. Box store channel is too thin in wall thickness My laminated glass was 0.350" thick. Besides bicycle tube or silicone, buytl tape is clean, cheap and effective. It has a play dough consistency you can roll into whatever thickness you want and the excess is just rubbed or trimmed off with a razor.
Satin, 3/8 legs for easier to bend corners, 9/16 wide overall minus /0.375" for the glass for a .093 wall versus typical 0.625 1/16th wall:
https://wgsonline.com/satin-anodized-al ... -long.html
https://www.homedepot.com/p/50-ft-Butyl ... /205945574
or
https://www.homedepot.com/p/M-D-Buildin ... /100353483
or
- MYTF
- Building: Gibbs Roadster
Re: Wind shield
I got my channel from Home Depot and the rubber strip from a local glass shop. I followed the directions from Jack at http://www.kineticvehicles.com/
I cheated as I didn't bend it across he top. I will make a full wind shield later/
I would have used the rounded corner channel from Jack but I am trying to go with a wind deflector to register the car without wipers.
- rx7locost
Re: Wind shield
This might be a good time to revisit up my old thread (pun intended) on my modification to the book design using tee nuts.
viewtopic.php?f=23&t=9225&p=96024&hilit=windshield+threads#p96024
kill no cone
Re: Wind shield
I think Jack at Kinetic had some nice areo material made for windshields.
● Aerodynamics are for people who can't build engines. ~ Enzo Ferrari
● I have a dream: My car has a new type of engine: a half-turbine half-reciprocated engine. I invented it! ~ Dr. Felix Wankel
● It has occurred to me, amateurs built the ark and professionals built the titanic.
