The Vodou frame design, or a frame designed for Miata IRS...
CouchingTiger
Building: Locost Miata
Post by CouchingTiger »
Hello! This is my first post, and I have been researching and reading for a while. I would like to build a Locost with Miata Independent Rear Suspension. I have the plan set for the Vodou design (hopefully the latest), and I like it a lot, but I can't find much about the company, and most importantly other builders who've ACTUALLY used these plans to build one. I bought Keith Tanners book, only to find out he BOUGHT his frame. Can anyone on LocostUSA give me insight on the Vodou plans that have actually used them to construct a Locost? Are there errors? Gotchas? Omissions? Is there a builders manual somewhere? If not, has anyone built an IRS Miata Locost from plans that are relatively complete? There must be builders out there happy with a frame design...
Warmest regards, Christian
Miatav8,MstrASE,A&P,F
Re: The Vodou frame design, or a frame designed for Miata IR
Vodou is supposed to be based on the haynes book. The plans are just general guides.
You could use the subframe for the diff wing mounts and lcas or even the struts depending on your actual goals.
Driven5
Post by Driven5 »
So few cars actually get completed in general, with those being from so many different donors and with different mods, that there probably aren't many common scenario examples to follow, but here are a few Vodou threads to check out:
https://www.locostusa.com/forums/viewtopic.php?f=35&t=19352
http://www.locostusa.com/forums/viewtopic.php?t=19008
http://www.locostusa.com/forums/viewtopic.php?t=19249
https://locostusa.com/forums/viewtopic.php?f=35&t=16059
https://www.locostusa.com/forums/viewtopic.php?f=35&t=14087
Also check out the Saturn plans, as I seem to recall there being a fair bit of documentation available on the net for them at one point... Even if not on this site:
https://www.locostusa.com/forums/viewtopic.php?f=35&t=15496
https://www.locostusa.com/forums/viewtopic.php?f=35&t=17008
FieroReinke
Building: Miata Based 7
Post by FieroReinke »
I built mine based on the Voodoo / Saturn plans, but only as a starting point. I made many changes and alterations as I went. I think the suspension design can use some improvement, but I was going to getting the car on the road more than for optimal suspension. You can easily get into analysis paralysis with suspension and not actually build a car.
The changes I made, off the top of my head,
1) on the suspension, I built using rod ends rather than bushings, but used their overall arm length dimensions.
2) I moved the scuttle back ~6" to close up the cockpit
3) laid out the inner rails to match my engine location rather than follow plans.
4) laid out the transmission tunnel to match my engine / trans location rather than follow plans.
5) many little things, like seat supports, triangulation, diff mount, I made my own design.
Overall, I don't remember any significant issues with the Voodoo plans, but with any plans on a car like this, you can't take the plans as gospel. You have to think about what your doing now and 10 steps down the road on how everything will go together. The plans are just a starting point, but for me figuring it all out was a lot of fun.
RTz
Post by RTz »
My frame is built specifically for NA Miata IRS. I'm 6'-5" and fit comfortably. Use at your own risk ;)... viewtopic.php?f=35&t=17715
Peace, Ron
flyguyeddy
Building: v8 locost
Post by flyguyeddy »
One of the two frames mentioned here is almost exactly the same as the haynes manual. The differences being in the rear suspension areas. Im tempted to say its the saturn plans, but its been a while since i worked on my frame.
From what i gather, the Talon motorsports TMXR frame is exactly built to haynes specs, and had a special diff cover to eliminate the wings from the miata unit.
Heres a shot of the rear arms of the talon frame
