I saw in a video that a British kit car company uses brazing to join steel tubings for the chasiss.
Some uses brazing to build custom motorcycle chasiss
What are the advantages of brazing?
For DIYers, is brazing an easier process than welding? Is it easier to control than welding? Is it more suited for begineers who is intimidated to weld?
Does brazing produce better strength joints than weldings?
Welding vs brazing for steel tubing chasiss
- Building: Super 7 replica
- davew
- Building: 4age locost
Re: Welding vs brazing for steel tubing chasiss
It is called nickel-bronze welding. It has a T/S of 80,000 PSI, Vs your typical 50,000 PSI for a MIG weld. Just the nickel-bronze rod to build a frame will cost between $8oo to $900. Then you need the equipment to feed in the flux into the welding hose plus the oxy-acetylene equipment.
It's not locost $$$
The main advantage is you do not have the heat effected zone with carbon embrittlement because of the lower temp, along with equal or better strength.
You can easily pick up sufficient MIG welding skills in just an hour or two of practice. Check out your local junior college for classes or on-line instruction!,
It's not locost $$$
- Lonnie-S
- Building: V6 Powered Locost
As Dave points out above, the process is not low cost.
We Americans tend to make fun of the Brits for not doing the Macho thing, which is welding. However, they have employed the bronze welding technique very successfully for years. The proof is in the pudding. They're produced many outstanding and successful race cars using it.
I haven't done any brazing (the American term for using a similar, but not identical method) since high school shop. However, it is easier in many ways compared to welding. Like soldering, brazing "follows the heat" and flows with it. Once you get that down, it's pretty easy to do.
- Mid-Engined Maniac
- Building: Midlana
- Contact:
Buried somewhere in one of my old build diaries, is a pic of a brazed motorcycle frame. It appears to be TIG welded, but isn't - it's brazed! The guy who did it is truly an artist.
- Building: zuk pwrd roadster
Joint fit-up is also more critical in brazing, better for bicycle frames
- Kinetic Research
- Building: Mid engined 3 seater
One of my customers is a local legend, his work is exemplary and he really likes the way the brazed joints transfer loads between tubes, of course 50 years of experience helps....it's fair to say his work has stood the test of time in very demanding conditions.
http://www.manxnorton.co.nz/
- RTz
That's a skill I regret not learning when I wore a younger mans shoes.
Peace, Ron
Users browsing this forum: Ahrefs [Bot] and 6 guests
