Thinking about you guys. (Isuzu v6)
Potential donor discussions and troubleshooting, gas, diesel, electric powered builds etc..
kickerfox
Building: RX-8
Re: Thinking about you guys. (Isuzu v6)
Post by kickerfox »
Oh I see what your saying. That would make a great drivetrain.
For whatever reason, that reminds me. I'm going to weigh the short block, the heads, and the clutch assembly to get some numbers for you. I won't be able to figure a complete engine weight but I'm sure you guys can guesstimate the manifolds and accessories.
kickerfox
Building: RX-8
Post by kickerfox »
kickerfox
Building: RX-8
Post by kickerfox »
Wanted to update this with some interesting info about the Isuzu 6VD1 engine.
"6VD1 - V6 It is nearly unknown that the Isuzu 6VD1 V6 engine was a 1996 Championship Winning DTM engine. In the early 1990's, Opel (GM Germany) was having problems with their narrow angle V6 engine in the Calibra DTM race cars. They eventually decided to use the Opel Montery (Isuzu Trooper) 3.2 liter all aluminum 6VD1 engine, because the wide 75 degree angle and more durably block structure could handle higher engine speeds better than their own engines. Cosworth destroked the 6VD1 to 2.5 liters, built custom heads, individual throttle body induction system, and dry sump lubrication system. According to the most conservative power specs, the engine made 457 HP at 12,000 RPM. The Japanese sources cite 485 HP at 12,300 RPM. The race shops who bought the remaining engines, after DTM changed their engine displacement rules, state that the true specs are 540 HP at 15,000 RPM. The Isuzu V6 would make a very good power plant for a race car, if built correctly."
I think it's in this video somewhere. https://www.youtube.com/watch?v=RXtoXw4jpXs
kickerfox
Building: RX-8
Post by kickerfox »
The final solution for the clutch is...
Cut the Isuzu flywheel surface flat and drill the holes for a '94 Camaro pressure plate. Use '94 Camaro clutch disc. Make a spacer to hold a pilot bearing. Now you can use a WIDE range of transmissions used in GM vehicles. There will be plenty of room to shim a concentric throw-out bearing. Use a 13/16" master from a 1980 Jeep CJ7 and save about 70 bucks over a Tilton. It's the same bolt pattern as the Tilton and Wilwood if you decided to change it later. You need 1" of master piston throw.
kickerfox
Building: RX-8
Post by kickerfox »
I was mistaken about the total weight being 163kg (359lbs). It's actually 133kg (293lbs). Supermarine was including the 30kg (66lb) prop reduction.
Shave off at least another ~10lbs if you make your own intake. I'll get the long block weight soon.
carguy123
Building: Choppercrosser
Post by carguy123 »
You make me want to do this in my car.
kickerfox
Building: RX-8
Post by kickerfox »
Do eet! Do eet naow! To da choppeh! (chopper = junkyard?) :)
215tq@3000rpm 205hp@5400 in the Amigo. Supermarine gets 250hp out of it with just a tune. Assuming the RPMs didn't change that's 243tq.
If you want to know what it sounds like just watch videos of the Mazda KLDE 2.5L v6. Ford Probe, MX6, or 626. Or the Miata KL swaps. Same firing order. 1-2-3-4-5-6
The Miata in front is a KL swap. https://www.youtube.com/watch?v=8aXn9L6MRys
As for the Flywheel modifications. Take a sawzall and lop off the 3 raised "towers" (see unmodified flywheel pic above) then have it resurfaced. The 6 holes you'll have to have done at a good machine shop. Cheap modification though. Cost me $60 to have it done plus I had them turn is smaller. Another $49 to balance. The entire flywheel/clutch/pp is only 34lbs. Should be a very snappy throttle. Throw on some Triumph 595 triple throttle bodies (under $100 on ebay) and I bet it'll really rip.
Oh, and the '99 Amigo ECU's rev limit is 6500rpm. So peak HP at 5400 is a great spot for them to put it. Gives about 2000RPM width. Now I'll have to recheck the MA5 trans shift points again.
kickerfox
Building: RX-8
Post by kickerfox »
This engine is going to look sweet when it's done.
ngpmike
Building: Granny Flat
Post by ngpmike »
Bump!
BRAAP
Building: Admiring currently
Contact:
Post by BRAAP »
Bumpity bump bump.
Intrigued by this power-plant, especially for a LoCost project...
ngpmike
Post by ngpmike »
It's been over 9 months since we last heard from Kickerfox. I wonder how it's going? May have to go check out the RX forum. :?
Laminar
Building: Hopes and Dreams
Post by Laminar »
He's posting regular, gradual updates there. The RX guys continue to be giant assholes.
Ford 5.0 into an M3
ngpmike
Post by ngpmike »
No real surprise there. :BH:
Thanx for the update
300D50
Building: 13B gull-wing ME-RWD
Post by 300D50 »
Mmm, small V6 goodness...
I think this is a good fit, keeps it Japanese, keeps the engine weight down, and shouldn't kill handling too much if the weight distribution is kept in check.
I'm envious of the torque potential too. The 6-5-4-3 hill climbing can get old quick.
Walt
06 RX-8 Shinka
04 RX-8 GT
06 325xi
kickerfox
Building: RX-8
Post by kickerfox »
Just figured I'd drop by here and see if there was any more interest. I'd REALLY REALLY REALLY love to see this engine in a Locost. Someone PLEASE do it. I'll give you all the support I can. Pop on Craigslist. There's a TON of Rodeos/Troopers/Amigos with bad transmissions and rotted frames but perfectly good engines. For under a grand you can get a 3.2L or 3.5L powerplant with the weight of an iron block i4 but 50% more power. DO IT!
Here's a little bracket I've been working on to clean up the accessories. Look where the alt and ac sit. LOW LOW LOW! The AC is easily bypassed by rerouting the belt, as is the power steering. If only the alternator was kept it'd be a tiny little serpentine belt. :)
