Driven5 wrote:bob wrote:Not finished yet but I think the 302 ford I am using after going on a diet is under 350lbs...
Bob
Is this as weighed by you with all noted components, or are there any approximations or second hand weights involved?
A bit of both really, I weighed a roller cam 302 which is the heaviest of them complete with all the lifters,pushrods,sump,flywheel,steel pulleys, waterpump, head bolts etc and put the stack on top . That weighs app 277.2lbs. I still have to weigh the ali heads with the valves in which will be app 30lbs each and the rocker covers. To deduct from the weight will be the lighter pulleys , the shallow sump, the lifting chain and the lighter overall weight of the non roller 302. 350lbs or under is a realistic complete weight. Neither engines include a distributor because I am going crank fired wasted spark.
Bob
Engineer: noun en·gi·neer \ˌen-jə-ˈnir\ - Someone who does precision guesswork based on unreliable data provided by those of questionable knowledge. (See also: wizard, magician, sorcerer, witch, miracle worker)
