Anyone in Houston - Test Fit?
Moderator: dhempy
- JAMADOR
- Building: FC RX7 Based
Been reading on here for a couple weeks & am thinking about diving in on doing a full DIY.
Wanted to get a 'test fit' in a completed car before getting started, just to be sure the fit is good. I'm 6'0" 160lbs, so I don't forsee a problem, but just want to be sure.
Anyone in the Houston area (I'm in N Spring) available for a demo/test fit?
1975 MG Midget
13B Powered Rotus Geauxkart
- Driven5
Re: Anyone in Houston - Test Fit?
If you have trouble finding someone local, you can always mock it up in wood.
- rx7locost
6  ft and 160 lbs can easily fit in a "book" chassis. A driver 6 ft and 200# plus fit in my car with tilt steering. Shoe size/type seems to be a more of a factor in many builds. That being said, there are so many variable in builds, that a test fit in one persons car may feel too tight while somebody else's build using the same chassis size you might float around in. I know this doesn't help. For clarification, re-read the first sentence and start your build. We are here to help even though this post may not help you much.
- JAMADOR
Thanks, I'm in a 9-9.5 shoe, so probably not a problem there. With how custom these seem, compared to a Caterham I guess, it's easier to tailor make it to suit.
							1975 MG Midget
- Lonnie-S
- Building: V6 Powered Locost
Remember, you can build a wider chassis (e.g., McSorley 442) and or narrow the tunnel.  You should be fine however, with a size 9-1/2 shoe in a standard chassis (Haynes or Champion).
Damn!  That front slip angle is way too large and the Ackerman is just a muddle.
- JAMADOR
Lonnie-S wrote:Remember, you can build a wider chassis (e.g., McSorley 442) and or narrow the tunnel. You should be fine however, with a size 9-1/2 shoe in a standard chassis (Haynes or Champion).
Thanks.
I'm narrowing my focus to a Miata-based build, so I'm going to need to figure out which is the best chassis for that, getting on the lookout for an NB1, unless an NC makes a good donor, as they're much more plentiful.
But, it'd still be nice to meet a local or two
1975 MG Midget
- Lonnie-S
@JAMADOR
There are multiple plan sets (most free) for Miata versions of the Haynes Roadster. It is also larger that the Champion (Book) chassis and you would fit for sure. It was also engineered to a higher degree.
- JAMADOR
Thanks, I'll start hunting for a good set of plans for a Haynes chassis.
I think I've read that Vodou is a source for the Haynes plans?
1975 MG Midget
- Lonnie-S
JAMADOR wrote:Thanks, I'll start hunting for a good set of plans for a Haynes chassis.
Yes, that's one set. There are others too, but I'm not familiar with them. My build is a one-off.
- JAMADOR
Lonnie-S wrote:JAMADOR wrote:Thanks, I'll start hunting for a good set of plans for a Haynes chassis.
Found a copy of the VoDou plans.
Just need to find a suitable donor & go from there.
1975 MG Midget
