Prebent Tubing
thehiddenproject
Building: Vodou + Miata
Prebent Tubing
Post by thehiddenproject »
Hi Guys,
I am doing the rear bulkhead or the boot of the frame. The haynes roaster plan asks for 19mm tubing at a radius of 84mm. I was wondering if theres a place online where I can buy prebent elbows and just weld them to straight tubing. A lot easier than buying a bender or making a jig for it.
RoyzMG
Building: Honda S2000 based
Re: Prebent Tubing
Post by RoyzMG »
The McSorley drawings show this tube to be 2.0" Radius at the outer surface of the bend. See drawing below. Columbia River Mandrel Bending offers a 3/4" diameter mandrel bent, 180 degree piece that is a 1.75" R at the centerline. See attached link.
http://www.mandrelbends.com/mandrel-bends/mild-steel-16-gauge/0-75-mild-steel-1-75-radius-16-gauge-180-deg-mandrel-bend.html
This is what I used and it works great.
Roy
benny_toe
Building: +4 20 valve screamer
Re: Prebent Tubing
Post by benny_toe »
: :D :D
Larry in Seattle
benny_toe
Re: Prebent Tubing
Post by benny_toe »
: :D :D
The cost of a bender to bend these in itself would be prohibitive unless you could really make heavy use of it. The cheapies won't cut it. These are a bargain for just 2-4 bends.
Larry in Seattle
ChanoquinII
Building: Locost 442
Re: Prebent Tubing
Post by ChanoquinII »
I used the corners of a repurposed ping pong table.
I am sure you could use some other furniture bends.
Locost style..
tibimakai
Building: 442E
Re: Prebent Tubing
Post by tibimakai »
Thanks for that link.
How about the upper corners? There is a place where can I order them, or you guys using the same thing at all four corners?
Tibor
'20 Alfa Romeo Stelvio daily
Locost/442E in progress
Users browsing this forum: Ahrefs [Bot] and 6 guests
